How Does the Lindemann Constant Influence Melting Points in Solids?
  • Thread starter Thread starter Irrelephant
The discussion centers on the use of the Lindemann constant in predicting melting points for a simulator. The user seeks clarification on the formula involving the Debye temperature, Planck constant, atomic spacing, Boltzmann constant, atomic mass, and the Lindemann constant. It is noted that the Lindemann constant is generally considered constant for specific crystal structures but can vary between different structures. However, empirical evidence suggests that the formula may not accurately predict melting points for many substances due to questionable underlying assumptions. Overall, the conversation highlights the complexities and limitations of using the Lindemann constant in melting point calculations.
Irrelephant
I'm trying to make a simulator for melting points...
I've been on wikipedia, and the formula('s) they give for predicting melting point are very confusing, could someone explain them to me?
I plan to use the formula:
Where θD is the Debye temperature and h is the Planck constant, a is the atomic spacing, kB is the Boltzmann constant, m is the atomic mass, and where 'c' is Lindermanns constant...
Now I believe I can get the values for every variable in the equation ok, EXCEPT 'c' lindermanns constant, is this a set value? Or does it vary? -If it does vary how can I find it out?
Please explain in as much detail as possible, (I'll need it!)
Thanks a lot :smile:
Anyone? :(
Lindemann originally found a related formula empirically; "The Theory of the Properties of Metals and Alloys" (Mott and Jones, 1936) notes that "Lindemann's formula has not at present received a theoretical explanation." Wikipedia shows a derivation so clearly someone added a derivation later. The best description I can find is:
http://phycomp.technion.ac.il/~phsorkin/thesis/node4.html
This page says that the Lindemann constant is supposed to be constant for a particular crystal structure, but to vary between different structures. Experiments have, however, shown that the formula as a whole doesn't do all that well, and the linked web page further notes that the assumptions backing the derivation of this formula aren't as valid as one would like for many substances. This is, unfortunately, the best I can find. Good luck.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
