Line passing through an Ellipse and a Point
Figurelli
Please Help! Line passing through an Ellipse and a Point
Hi guys, I'm new to the forum and I could really use some help with this problem.
There is an ellipse with the equation: (X^2/4) + Y^2 = 1
There is a point on the graph (4,0)
Find an equation that passes through the line and the point...(must use the chain rule)
(X^2/4) + Y^2 = 1
I attempted to derive the slope of the circle: (DY/DX) = (-.5X)/(2Y)...
What do I do from here? Was that part even right? Thanks!
The line y=0 passes through the point and the ellipse. I think you want a line that passes through the point (4,0) and is tangent to the ellipse, right? In which case there are two of them.
Yes, I suppose you could find either equation but the one in the picture shows the line with a negative slope...
You need two equations for slope, or dy/dx. One is the slope of the upper half of an ellipse. The other is for a line that passes through the point (4,0).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
