What is the longest wavelength for ionizing ground state hydrogen atom?
Electromagnetic radiation can ionize atoms if the photons have sufficient energy to remove an electron. For the ground state hydrogen atom, the longest wavelength capable of ionization corresponds to a transition from n=1 to n=infinity. Using the Lyman series formula, the calculated wavelength is approximately 91.3 nm. The energy deficit for the electron in the ground state is -13.6 eV, which informs the required photon energy for ionization. The discussion concludes with the correct wavelength determined for ionizing hydrogen.
Dart82
Is it possible to use electromagnetic radiation to ionize atoms. To do so, the atoms must absorb the radiation, the photons of which must have enough energy to remove an electron from an atom. What is the longest radiation wavelength (nm) that can be used to ionize the ground state hydrogen atom?
Lyman Series:
1/lambda = R {(1/nf^2) - (1/ni^2)}
According to my notes, the lyman series consists of transitions TO the ground state (n=1) starting with the first excited state (n=2). What i am having trouble with here is that when they say "What is the longest wavelength that can be used to ionize the ground state hydrogen?" Are they asking what wavelength of radiation will cause hydrogen to go from n=1 to n=0? Should i be using the Balmer or Paschen series instead of the Lyman? I know how to work the math part of the problem but i am confused as to what values i should be using for n.
If you are initially in the ground state, then to remove the electron you need to raise it past all of the bound states. You could sort of say you want to move it to n=infinity.
What you need to know is the energy defecit of the elctron in the ground state. Each level has a negative energy associated with it. In hydrogen, n=1 , the deficit is -13.6 eV. Guess how much energy the photon must have to free this electron?
For the Lyman formula to work, you are going from energy level 1 to energy level "infinity," not to zero.
edit: Dang. Beat again.
how does this look?
lambda = R [(1/infinity)-(1/1^2)]^-1
lambda= 9.12x10^-8 meters or 91.2 nm
Nope. It's 91.3 nm:biggrin:
got it right finally. thanks
