Linear acceleration with letters instead of numbers
The discussion revolves around a physics problem involving a lift that accelerates, travels at constant speed, and then decelerates, with the goal of expressing the time spent at constant speed in terms of total time and distance. Participants analyze the relationships between time, distance, and acceleration, particularly focusing on the maximum velocity and the equal durations of acceleration and deceleration phases. The consensus is that the time spent accelerating (t1) is equal to the time spent decelerating (t3), which simplifies the calculations. There is an emphasis on using kinematic equations to derive the necessary relationships without needing to isolate the maximum speed. The conclusion is that understanding the symmetry in the motion is key to solving the problem effectively.
Woolyabyss
A lift starts from rest and travels with constant acceleration 4 m/s^2.It then travels with uniform speed and comes to rest with constant retardation of 4 m/s^"
The total distance traveled is d and the total time taken is t.
Show that the time spent traveling at a constant speed is (t^2 - d)^(1/2)
I called the maximum velocity "v", the time spent accelerating "t1", the time spent at constant speed "t2" and the time spent decelerating "t3" distance traveled when accelerating "d1",when at constant velocity "d2" and when decelerating "d3"
I used v = u + at, to find that t1 = v/4 and t3 = v/4.
I then multiplied the times by (1/2)v
to get the distances in both cases d1 = v^2/8 and d3 = v^2/8.
I then said d2 = vt2 =d - (v^2)/4
I divided v by both sides to get t2= (d/v-(v/4).
I made t1 + t2 + t3 = t and simplified to get (4d + v^2) / (4v) = t.
I tried to isolate v but couldn't since there was a v squared.
My main problem here I think is I can't get v on its own so i can't get rid of v in t2.
Any help would be appreciated.
What you are looking for, in your notation, is t2 in terms of t and d. Don't worry about v. Write down the kinematics equations for each part of the path, using forms that only involve distance, time, and acceleration, since that is what you are given.
Am I not required to to use the maximum speed "v" since d2 has no acceleration.The only way I can express it is in terms of speed and time isn't it?
You can do that if you want, but it would be simpler in the end to express that speed in terms of what you already know.
Hmmm, after looking at this problem, does it not require that his t1=t3, or am I wrong? I get the right answer if I assume t1=t3 I think.
The deceleration during t3 is equal and opposite to the acceleration during t1. The initial and final velocities are the same. Doesn't that imply t1=t3?
Yep, when I first read it though I didn't think it specified that it started and stopped at rest.
