Linear algebra (impact of solution of theory of linear equations)
hoju
I am currently taking the first college level linear algebra course and have a question.
Consider the system of equations:
1 3 2 |1
0 -4 5 |-23
2 2 9 |t
Find values of t for which solutions to this augmented matrix can be obtained. Explain the implications of this example in the theory of linear equations.
Answer:
I found that t=-21 and that the solution is of the form {x, y, z} = {-1/4(23z+65), 1/4(5z+23), z}. That much is correct. What I don't know is what the bold statement above is asking of me. Any help is appreciated. Thanks.
In row-reducing this augmented matrix, I found that if t = -21, the system has no solution. For a different value of t, I found the solution you show.
For implications of this example in the theory of linear equations, I'm not sure which implications the text author has in mind, but I would start with the geometric significance of your solution set.
Thanks for the reply Mark44. Here is the work I did to find t.
1 3 2 |1
0 -4 5 |-23
2 2 9 |t
row reducing
1 3 2 |1
0 -4 5 |-23
0 -4 5 |t-2
1 3 2 |1
0 -4 5 |-23
0 0 0 |t-2+23
1 3 2 |1
0 -4 5 |-23
0 0 0 |t+21
It follows that t=-21 is necessary for the system to have a solution so that 0=0 in the last row. Did I miss something?
I know that the system has an infinite number of solutions that depend on the value of z, but I am still not sure how this impacts the theory of linear equations. Probably because I am somewhat unfamiliar with the theory itself. The book isn't much help.
I am guessing that the theory of linear equations states that the roots of each equation in the system are the same if the system has a solution, but in this case the existence and identity of the solution are restricted by t and z, respectively. Would that be on the right track? Thanks for the help.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
