When Do Span Intersections Equal Span of Intersections in Vector Spaces?
batballbat
S_1 and S_2 are subsets of a vector space. When is this:span(S_1 \cap S_2) = span(S_1) \cap span(S_2) true? Prove it.
conjecture: iff the two subsets are vector spaces.
It's true when both sides are subsets of each other.
Choose an arbitrary element in each set and show it belongs to the other set both ways.
sorry, but that is of no help. I am asking for a condition and a proof for "iff".
Well, what do you know and what have you tried? Do you know what "span" means?
Or do you just want someone to do the problem for you?
ok. please delete this post.
It's easy to see that your guess is wrong. Let ##\{e_1,e_2\}## be the standard basis of ##\mathbb R^2##. Let ##S_1=\{e_1\}## and ##S_2=\{e_1,e_2\}##. We have $$\operatorname{span}S_1\cap\operatorname{span} S_2 =\operatorname{span}(S_1\cap S_2)$$ but neither ##S_1## nor ##S_2## is a subspace.
You will have to put in some effort of your own if you want help with the problem. In particular, you should include the definition of "span". Is ##\operatorname{span}\emptyset## defined?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
