Linear algebra- what is a vector space?
preluderacer
I looked up what is a vector space online and it always gives like formula or long explanations. In a couple sentences can you tell me exactly what a vector space is? I know it has to go through the origin, but what else is true about a vector space?
I suggest you to look at http://mathworld.wolfram.com/VectorSpace.html.
I don't know what you mean by "it has to go through the origin". A vector space must contain an element (called vector) that is neutral under addition. In other words, there must exist a vector say \vec 0 such that for any vector \vec x in the vector space, the following hold: \vec x + \vec 0 = \vec x.
It just means the 0 vector must be in that set (from memory...)
If the following axioms are true for all objects u, v, and w in V and all scalars c and k then V is called a vector space and the objects in V are called vectors.
(a) u + v is in V
(b) cu is in V
(c) u + v = v + u
(d) u + (v + w) = (u + v) + w
(e) 0 in V, such that for all u in V we have u + 0 = 0 + u = u.
(f) For every u in V there is -u such that u + (-u) = 0.
(g) c(u + v) = cu + cv
(h) (c + k)u = cu + ku
(i) c(ku) = (ck)u
(j) 1u = u
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
