Linear Generator Coil Requirements
The discussion centers around the design requirements for a linear electricity generator, specifically focusing on the coils and magnets involved in the generator's operation. Participants explore various aspects of generator design, including magnetic fields, coil configurations, and electrical connections for power sources.
  • Homework-related
  • One participant suggests that the "shake flashlight" serves as a practical example for understanding linear generators, while expressing uncertainty about the specifics of coil and magnet design.
  • Another participant notes that stronger magnets and closer proximity to coils can reduce losses and increase voltage output, emphasizing the importance of wire turns and magnet speed in power generation.
  • A request for reference materials on linear generator design is made, indicating a need for further resources.
  • A separate inquiry is raised regarding the feasibility of connecting multiple DC power sources in series and parallel configurations, with specific questions about voltage and current requirements for such connections.
Participants have not reached a consensus on the specifics of coil and magnet design for linear generators. There are multiple viewpoints regarding the connection of DC power sources, with some questions remaining unresolved.
There are limitations regarding the assumptions made about the design of linear generators and the electrical configurations of DC power sources. The discussion does not provide definitive answers to the technical questions posed.
This discussion may be useful for individuals interested in electrical engineering, generator design, or those seeking to understand the principles of magnetic fields and electrical connections in practical applications.
jrx07
Hey I'm interested in designing a linear electricity generator (think magnetic piston moving back and forth in a coil housing) and was wondering if anyone could reference where I should look for designing the coils/magnets. Thanks!
The "shake flashlight" is a pretty good place to start, LOL. I am uncertain what you mean by "designing the coils/magnets." The stronger the magnet, the higher the B field, the closer the magnet is to the coils, the lower the losses, the more turns of wire, the higher the voltage and higher the resistance for any given size wire. The faster the magnet moves, the higher the power output. If you want to quantify things, you might review solenoids:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html
Your "generator" is just a solenoid in reverse.
Fish
jrx07, Have you found any good reference material for the design of a linear generator?
I need to add two, or more (say 20) dc power sources, with a combination of series, parallel connection to obtain both Voltage add-up (in Series) and current add-up (in parallel), because i will be using a series-parallel combination for that.
Please advise that:
1. can the above be done without facing complications.
2. for adding two or more dc power sources (for battery, and for electronic), the
voltage of each dc power source must be equal (say all are delivering 5v, or 3v, or
whatever)?
3. should the current output also be equal of all dc power sources to be added in
Series/Parallel/Series-Parallel, if the above (2) is true (say all should be delivering 4
mAmp, or 5 Amp, or whatever?
4. Please give detailed answer, with diagram, if any, i shall be grateful.
