Load Angle of Synchronous Motor at No Load
  • Thread starter Thread starter rob1985
    Angle Load
The load angle of a synchronous motor at no load is effectively zero degrees, as there is no active power being generated. This is because the rotor's magnetic field aligns with the stator's resultant magnetic field when no load is present. While some participants debated the terminology, the consensus is that the absence of load results in no load angle. The alignment of the rotor and stator fields confirms this understanding. Therefore, the load angle at no load conditions is indeed zero degrees.
rob1985
hi all,
Just a quick question, what would the load angle be of a synchronous motor when running at no load. would it be 0 degrees or 45 degrees
What do you think and why?
to be honest I am really not sure, I suspect it is zero as there is no load so the magnetic field of the rotor is the same as the stator. am I on the right tracks
I agree w/ you, although I'm not sure I'd call it a "load angle" since there's no load :smile:
Yes. Active power is proportional to the sine of the load angle. No load, no active power, hence zero load angle.
No. You can say rotor magnetic field and stator magnetic field are aligned, or in other words, rotor is aligned with the resultant magnetic field.
Likes Neil Hayes and jim hardy
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
