Solving Algebraic Equations Involving Logarithms
  • Thread starter Thread starter Corkery
    Logarithms
Corkery
Solve Algebraically:
Log(subscript4) (a^2 + 2) = Log(subscript 4) (2a + 10)
other equations that are similar which I can't do are:
-Log(subscript 5) (x + 3) + Log(subscript 5) (x - 2) = Log(subscript 5) 14
-Log(subscript 2) (2x + 6) - Log(subscript 2) x = 3
not sure if this is right but I think you would divide by Log(subscript 4)
Log(subscript4) Log(subscript4)
canceled those out leaving:
a^2 + 2 = 2a + 10
expand the equation:
this is where i get lost, unless I am doing it completely wrong. Please help.
Your solution is essentially right, but the formalism is painfully wrong. If f(x)=f(y) you cannot divide by f. You have to apply the inverse function of f. The inverse of Log(subscript4) is 4^. As in 4^(Log(subscript4)(x))=x. And a^2 + 2 = 2a + 10
is a harmless quadratic equation. Don't get confused there, just factor it or use the quadratic equation.
When doing log equations, you should try to remember all the formulae. Some useful are:
(1) logab + logac = loga(bc)
(2) logab - logac = loga(b / c)
(3) loga(bc) = c loga(b)
(4) The change base formula:
\log_{a}b = \frac{\log_{c}b}{\log_{c}a}
(5) Since logarithm is either strictly increasing or strictly decreasing (i.e, 1-1 function), we have:
\log_a b = \log_a c \Leftrightarrow b = c
You cannot divide logab by loga to get b, it's as meaningless as saying that:
\frac{\sin x}{\sin} = x
I'll help you do the first one, and let you try the other 2 by yourself. See if you can get it. :)
log4 (a2 + 2) = log4 (2a + 10)
Using (5), we have:
<=> a2 + 2 = 2a + 10
<=> a2 - 2a - 8 = 0
\Leftrightarrow a = 4 \quad \mbox{or} \quad a = -2
a2 + 2, and 2a + 10 should all be positive. And both values satisfy the requirements, so we have 2 solutions:
Is it cear?
Can you do the other 2? :)
VietDao, why should a be positive? You need a2+2 and 2a+10 to be positive, you don't need a to be positive. Note, those expressions are positive for both a=4 and a=-2.
Whoops, I thought that a was the base :blushing: :cry:. Er... stand corrected. :smile:
Thanks. :blushing:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
