How Do Lorentz Transformations Affect Light Signal Velocities?
JonathanT
Consider a light signal propagating in some arbitrary direction, with
vx \neq 0
vy \neq 0
vz \neq 0 and
vx2 + vy2 + vz2 = c2
Use the Lorentz transformation equations for the components of velocity to show that
v'x2 + v'y2 + v'z2 = c2
Combination of Velocities
v'x = (vx - V)/(1-vxV/c2)
v'y = (vy√1-V2/c2))/(1-vxV/c2)
v'z = (vz√1-V2/c2))/(1-vxV/c2)
I know this is just a simple algebra proof but for some reason I'm getting stuck on it. Maybe I'm using the wrong equations?
I would really appreciate being shown where to start for this proof. Thanks in advance for the help and/or time.
You should get the transformation equations for vx, vy, vz to the prime variables and insert them into vx^2 +vy^2 +vz^2 = c^2 to show this reduces to vx'^2 +vy'^2 +vz'^2 = c^2. Since the speed of light is constant in all frames, the change in frames should be invariant under the lorentz transformation. Just be careful with your algebra...if it starts to get too messy then you probably did a simplification that led you in the wrong direction.
Thank you. I apparently was making a stupid algebra mistake and over complicating it. Just knowing I was heading in the right direction helped. Made me find my mistake. Thanks again.
no problem!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
