Low Air Compressor CFM Still Works?
To test a mach 2 ramjet, a requirement of 50-72 CFM is noted, while the available compressors only provide 2 CFM. The possibility of running a 25 CFM air compressor at 50 CFM for short bursts is questioned, along with how to calculate the operational duration above the required CFM. Isentropic equations indicate a necessary tank pressure of approximately 115 psi for the desired outlet. The discussion highlights that typical air compressors do not allow for variable CFM settings, and suggests using a large reservoir tank to store and release compressed air quickly. Understanding the CFM rating as a measure of mass flow is also emphasized.
yangshi
Halfway through my thesis on a mach 2 ramjet, and I unfortunately realize that I need 50-72 CFM to test it. The only ACs I have are 2 CFM portable pancakes. Is it possible to run say a 25 CFM AC at 50 CFM for a short period of 10-60 seconds? Is there a quantitative way to find how long the AC will last above the required CFM?
I used isentropic equations to find that the required tank pressure is ~115 psi for mach 2 outlet, if that helps...
Are you using "CFM" as a measure of volume flow or mass flow? According to http://www.truetex.com/aircompressors.htm the CFM rating of an air compressor is a measure of mass flow.
I don't know how you can run a typical air compressor at a variable CFM. I suppose the flow rate varies as you make it work against more and more pressure, but haven't seen any compressors where you can set the CFM to a specific value.
Can you get a large reservoir tank and slowly fill it with compressed air, then release the air suddenly?
Likes bsheikho
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
