Calculating Maximum Resistance & Inductance for Theater Light Dimmer
The discussion focuses on calculating the maximum inductance (Lmax) and resistance (Rmax) for a theater light dimmer circuit. The user is tasked with determining Lmax required to vary the energy dissipation in a lightbulb rated at 1300 W by a factor of 4, using the relationship between power, voltage, and resistance. They derive a formula for Lmax based on the power ratio and ultimately calculate Lmax as 0.059. The user expresses uncertainty regarding the maximum resistance that can replace the inductor, indicating a need for further clarification on that part of the problem. The conversation highlights the complexities of RLC circuit calculations in practical applications.
reising1
A typical "light dimmer" used to dim the stage lights in a theater consists of a variable inductor L (whose inductance is adjustable between zero and Lmax) connected in series with a lightbulb. The electrical supply is 120 V (rms) at 60.0 Hz; the lightbulb is rated as 120 V, 1300 W. (a) What Lmax is required if the rate of energy dissipation in the lightbulb is to be varied by a factor of 4 from its upper limit of 1300 W? Assume that the resistance of the lightbulb is independent of its temperature. (b) What would be the maximum resistance of a variable resistor (adjustable between zero and Rmax) which can be used in place of an inductor?
I know the equations for RLC circuits, and I know P = (i^2)(R)
I'm really just stuck. I don't really understand the question. Are we increasing it by a factor of 4 or decreasing it? Can someone get me started on the right track?
I also know that P = V^2 / R
Taking the ratio of Pmax to Pmin we get
Pmax/Pmin = (Imax / Imin)^2 = ( (E/Zmax) / (E/Zmin) )^2 = 4
So
(sqrt( (R^2) + ((w*Lmax)^2) ) / R)^2 = 4
which implies that
Lmax = R / w (when we solve for Lmax in the above equation)
Thus, pluggin in for P = V^2 / R
we get ( (2V^2 / P) / w) = Lmax
Solving, I get Lmax = .059. Does this seem correct?
Now what about part b. Not sure about that one.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
