Solving LCR Circuit: Find C, I_rms, I_rms at Resonance
In a series LCR circuit with R=69.0 Ω and L=0.100 H, driven by a sinusoidal emf of Erms=6.70 V at 250 Hz, the current leads the emf by 54.0 degrees. To find the capacitance C, the equation tan(phi) = (WL - (1/WC))/R should be corrected to tan(phi) = ((1/WC) - WL)/R, reflecting the phase relationships in the circuit. The rms current can be calculated using Irms = IP/sqrt(2) and the impedance Z. The resonant frequency is given by Wo = 1/sqrt(LC), which will affect the rms current when the frequency changes. Clarification on the phase angle is essential for accurate calculations.
tomrja
Consider a series LCR circuit with R= 69.0 Ω and L= 0.100 H, driven by a sinusoidal emf with Erms= 6.70 V at frequency f= 250 Hz. The sinusoidal current leads the emf by 54.0 degrees.
a) Calculate the capacitance C.
b) What is the rms current in the circuit?
c) If the frequency of the emf is changed to the resonant frequency of the circuit, what is the rms current?
tan(phi)=(WL-(1/WC))/R
Ip= Vp/Z = Vp/sqrt(R^2+(XL-XC)^2)
Irms=IP/sqrt(2)
W=2*pi*f
Wo=1/sqrt(LC) resonant frequency
I solved tan(phi)=(WL-(1/WC))/R for C and got C=1/(W(WL-Rtan(phi)) then plugged in all given info to solve for C. It says that the answer is wrong and I am assuming that I plugged in the wrong phi. "The sinusoidal current leads the emf by 54.0 degrees." I don't know what this means. I have not started on the other two parts of the problem because I need to find C first. What am I doing wrong? Thanks!
Hi tomrja :smile:
(have a phi: φ)
i didn't read all of your post but the thing i quoted is wrong
tan\phi = \frac{\frac{1}{wC} - wL}{R}
thats because current in capacitor leads voltage by 90 and lags in inductor by 90
and for iRMS use
iRMS = ERMS/Z
hi tomrja! :smile:
it means that if V = Vmaxsinωt, then I = Imaxsin(ωt + 54°)
in other words, the impedance is Z = |Z|ei54π/180
