LV electronic ballast failures for halogen
  • Thread starter Thread starter nobledane
    Electronic
The discussion centers on the failure of electronic ballasts for 20W halogen lights after all three bulbs went out simultaneously. The user confirmed that the input voltage to the ballasts was 250V, but there was no output voltage, indicating a potential issue with the ballasts. Despite replacing the ballasts with new ones, the output remained non-functional, leading to confusion about the cause of the failure. Suggestions included testing the ballasts in a different location and temporarily using an incandescent bulb to troubleshoot the issue. The possibility of purchasing low-quality ballasts was also raised, prompting a recommendation to inquire about return rates at the store.
nobledane
Hi,
At my house i have in wall stair lights that are 20W halogens (x3). A week or so ago i switched on the 2 way switch from the bottom of the stairs and all three went at the same time. I thought it was the bulbs at first but quickly discovered they were fine. My next thought was the electronic ballasts so i pulled out the fitting and checked the AC voltage at the input terminals which measured 250V (note that the rcd/mccb did not trip when they went out) but nothing at the output terminal where there should have been 12V i believe. Hence i thought the ballasts were stuffed so i went and bought 3 new ballasts and put one in.. still nothing on the output side of the new ballast... strange.. so tried another one and still nothing on the output side of the second new ballast.. WHAT IS GOING ON? Scratching my head over this one...
Cheers,
nobledane said:
Hi,
Cheers,
Do you still measure 250V input when you are trying to run the ballast? If there is a loose wire in the feed line (like at one of the wire nuts), the open circuit voltage could still read 250V, but as soon as you try to draw a load current, it could be dropping to some low value through the resistance of the loose wire fitting...
That would also explain why all 3 went at once.
thanks - but yes there is still 250V when i try and run the ballast.. and it makes a humm as they usually do.. just nothing on the output of 3 different ballasts...
Hmm. That is indeed strange. Can you wire in an incandescent bulb temporarily to see if it works? Can you try the ballasts at a different, known-good location?
Maybe they are just cheap ballasts that break easily? Can you ask the store if they get many returns on them?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
