Magnetic field and direction question.
The magnetic field 25cm to the east of a straight vertical wire carrying a 12A downward current is calculated to have a magnitude of 9.6E-6 T. The direction of the magnetic field is determined using the right-hand rule, where the thumb points in the direction of the current and the fingers curl around the wire. For this scenario, the fingers curl in a clockwise direction, indicating that the magnetic field direction at that point is South. This conclusion is confirmed by visualizing the field's orientation relative to the wire. Understanding the right-hand rule is essential for determining the magnetic field direction around current-carrying wires.
rss14
Calculate the magnitude and direction of the magnetic field 25cm to the east of a straight vertical wire with a current of 12A downward through the air.
B = u(I / 2*pi*r)
Finding the magnitude is simple, but finding the direction is giving me difficulty.
The magnitude is 9.6E-6 T, and the direction is South. How is the direction South?
B = u(I / 2*pi*r)
You use the right hand rule to determine the direction. If you grab hold of the wire (figuratively speaking) with your right hand, with your thumb pointing in the direction of the current flow, then your fingers curl around the wire in the same direction that the B field circles the wire.
So grab the wire with your right hand with your thumb pointing down. Seen from above, do your fingers curl in the clockwise or counter-clockwise direction?
Clockwise, since the current faces downwards.
So the direction for that point (east of the wire) is South because that is the direction the field faces when it connects with the point?
Correctomundo.
