Magnetic Field and electron beam
The discussion centers on the behavior of an electron beam entering a magnetic field created by Helmholtz coils and the Earth's magnetic field. The electron beam initially aligns with the Earth's magnetic field, which is weaker than the field from the coils. Participants analyze the possible paths of the electron, considering the strength and direction of the magnetic fields. The conclusion leans towards the electron following a helical path primarily influenced by the stronger Helmholtz coil's magnetic field. Understanding the interaction of the magnetic fields is crucial for determining the electron's trajectory.
strawberrysk8
The original direction of the electron beam as it enters the magnetic field is along the earth’s magnetic field. If the magnitude of the earth’s magnetic field is 0.1 mT and the magnetic field due to the Helmholtz coils is 1.0 mT (perpendicular to the electron beam), the resulting path of the electron can be best described as:
a) A helical path with the axis of the helix roughly along the earth’s magnetic field.
b) A helical path with the axis of the helix roughly along the Helmholtz coils magnetic field.
c) A straight line
which is it? I have no idea!
We will help you, but don't give out answers here. "I have no idea" isn't an attempted solution. Work though each option logically and post your thoughts on why it could [not] be each one and we'll take it from there.
I am leaning towards c) a straight line.
I feel like the only way for an electron to move in a helical path is for the two magnetic fields to be diagonally intersecting.
Take into consideration the net magnetic field vectors...once you do so...take into consideration of what happens when the magnetic fields are not perpendicular to the velocity.
ok... then maybe b) since the strength of the helmholtz coil's magnetic field is larger than the strength of Earth's magnetic field. so the electron will follow a circular path, but along mostly the helmholtz coil's magnetic field
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
