Magnetic field detectable around axis of laser beam?
The discussion centers on the detection of magnetic fields around the axis of a laser beam in a vacuum. Participants explore whether magnetic field flux extends beyond the beam axis and if it can be detected without interrupting the beam. A reference to Bessel beams is made, indicating that the magnetic field oscillates and diminishes as it moves away from the axis. The conversation highlights the complexity of the topic and the need for further exploration. Overall, the potential for detecting magnetic fields around laser beams remains an intriguing area of inquiry.
Gravitron
I've looked for this subject but perhaps I'm asking the question the wrong way. Please advise.
Is there an extension of magnetic field (flux) beyond the beam axis of a laser? In other words, can one detect (or has anypone attempted to detect) the magnetic field around the a light beam in a vacuum without actually entering or interupting the beam?
Thanks
G
I'm sure of the correct answer. But I once looked up what the radially symmetric solution to a wave propagating in one direction is.
The only solutions is Bessel beams
http://arxiv.org/abs/physics/0006046 (page 6)
The magnetic field oscillates and falls off as 1/\sqrt{\varrho}
Maybe that's the answer.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
