sagigever
- 25
- 4
- Homework Statement
- inside a cylinder (not solid) with radius $$a$$ and infinite lengh there is a charge with uniform density $$\rho$$. the charge rotating inside the cylinder in speed $$\omega(r)=\omega_0\frac{a}{r}$$
find the vector of magnetic field inside the cylinder
- Relevant Equations
- $$\sum B_{\parallel} \cdot \Delta l = \mu_0 \ I_{enclosed} \ \text{, } \ \ \ \text{ or } \ \ \ \oint \vec{B} \cdot \vec{dr} = \mu_0 \ I_{enclosed}$$
I am sure I need to use Amper's law to do that. if I use the equation I mentioned above it easy to calculate the right side of the equation but I have problem how to calculate the path integral.
I know from right hand rule that the magnetic field will point at $$Z$$ and the current is in $$\phi$$ direction, so I want to take a loop of rectangle
but than I have no Idea how to calculate because $$\vec{B}_(x,y,z) not equal to \vec{B}_(0,0,z)$$
I hope I was clear enough to describe excatly where I am stuck
