Magnetic field in the center of the toroid
The discussion centers on calculating the magnetic field at the center of a toroid using the formula B = mu*N*I/2*pi*r. However, the book states this approach is invalid due to the lack of a constant field path through the center. Participants suggest using the Biot-Savart Law as an alternative method for this calculation. Guidance is requested on how to effectively apply the Biot-Savart Law in this context. The conversation emphasizes the complexities of magnetic field calculations in toroidal structures.
JasonBourneV
Can't this be calculated from B = mu*N*I/2*pi*r? Book explanation says that this can't be done because there is "no path through the center along which the field is constant" So I guess I must use the Biot-Savart Law. How should I go about doing that?
Thanks a lot, Doc Al, for the link!
