Magnetic field of a proton in circular orbit
The discussion revolves around calculating the magnetic field required to maintain protons in a circular orbit of 1 km radius with a given momentum of 7.63*10^-16 kg*m/s. The formula used is r = mv/qB, where the variables represent the radius, mass, velocity, charge, and magnetic field. An initial calculation yielded a magnetic field strength of 0.209 T, which was identified as incorrect. Participants are prompted to re-evaluate the calculation for accuracy. The focus remains on determining the correct value of the magnetic field in Tesla.
mjau001
Protons having momentum 7.63*10^-16 kg*m/s are held in a circular orbit of radius 1 km by an upward magnetic field. What is the magnitude of the field? Answer in units of T (Tesla).
r=mv/qB; where r is the radius of the circular orbit, m is the mass of the particle, v is the velocity of the particle, q is the charge of the particle, and B is the magnitude of the magnetic field
1000m=(7.63*10^-16 kg*m/s)/(1.6*10^-19 C)(B)
B=.209 T (wrong)
Hi mjau
Something's wrong with your calculation.Check it again
