What is the contribution of magnetic fields from individual loops in a solenoid?
The discussion clarifies a common confusion regarding the magnetic field contribution from individual loops in a solenoid. The equation derived from Ampere's law, B=μNI/L, accounts for the total magnetic field generated by the current flowing through the solenoid. It is emphasized that one should not sum the magnetic fields from the same wire multiple times, as this leads to incorrect conclusions. The factor N in the equation represents the number of turns of wire, not separate contributions from each loop. Ultimately, the misunderstanding stemmed from misapplying Ampere's law to the scenario of a solenoid.
OperationalAmp
I'm a bit confused with the equation for a long solenoid. The usual derivation has us consider a rectangular loop enclosing N number of currents over the length L through it. So by Ampere's law one gets B=μNI/L.
The currents and the loop look like this right?
x x x x
However, why doesn't one also consider the magnetic field contribution from the x's also? So that the sum will be B=2μNI/L? In fact one can find an infinite number of these loops each giving B and the magnetic field will sum to infinity. Which clearly is nonsense.
It's like Gauss's Law for charges, I have +q and -q separated symmetrically. I ask what's the magnitude of the electric field at a distance r from both charges. I enclose each with a Gaussian surface and I find the field from each of them +q/r² and -(-q/r²); the double negatives to take direction into consideration. Later I also have to add the fields together to get 2q/r², and not say q/r² is what's actually there just from taking one Gaussian surface.
I hope someone can enlighten me. Thank you! :smile:
I have realized what was my problem. I simply misunderstood Ampere's law. You see Ampere's law is going to give a magnetic field associated to a current flowing in one wire. And in the solenoid, it is one wire! So it is nonsense to sum the same magnetic field many times over. Only when there are two currents in separate wire do we add their magnetic fields. In the case of the solenoid, the approximation was that each wire winding are not connected to one another, thus explaining the factor N. So at the end of the day, one do not add magnetic fields arising from the current in the same wire.
Problem solved!
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
