How Far from a Conductor Is a Magnetic Field of 3.1x10^-5T?
To determine the distance from a conductor where the magnetic field strength is 3.1x10^-5T, the formula B = μI/(2πr) is used. Rearranging this gives r = μI/(2πB). Substituting the values, including the current of 12.5A, leads to an incorrect calculation of r as 8.1x10^5m due to an error in using the permeability constant. The correct value for the permeability of free space should be used to find the accurate distance. The discussion highlights the importance of using the correct constants in magnetic field calculations.
jalen
12.5A, 3.1x10^-5
How far from a long conductor passing a current of 12.5A is the magentic field of strength 3.1x10^-5T?
B= uI/2(pi)r
r=uI/2(pi)B
=(4pi)(12.5A)/ 2(pi)(3.1x10^-5T)
= 8.1x10^5m
u_0 isn't 4 pi.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
