C12B 2011 Problem 23Finding Zero Net Magnetic Field Points in Crossed Wires
The problem involves two long, perpendicular wires carrying equal currents, and the goal is to identify points where the net magnetic field is zero. The magnetic fields generated by each wire are analyzed using the right-hand rule, indicating that they will be perpendicular to each other in certain regions. The key to finding the zero net magnetic field points lies in determining areas where the magnetic fields from both wires are equal in magnitude but opposite in direction. It is crucial to identify the specific regions where this condition is met. Understanding these relationships will lead to the solution for the locus of points with zero net magnetic field.
HoneyDeeLite
Two very long fixed wires cross each other at right angles. They do not touch but are
close to each other. Equal currents flow in each wire in the directions shown below.
Indicated the locus of points where the net magnetic field is zero.
(I2)
------------------------> (I1)
B = m0I/2pir
I know from the right hand rule that the magnetic field due to I1 will curl around towards me (out of the page) on top of the wire and point away from me (into the page) when directly below the wire.
The magnetic field due to I2 will point into the page when to the right of the wire and out of the page when to the left of the wire.
But it seems that the directions of the two fields will always be perpendicular to each other and thus never cancel out. How can there be a locus of points where the net magnetic field is 0?
I am not sure why you think the fields will be mutually perpendicular since they both go into and out of the plane (ie. the plane formed by the wires).
What you want to find are points where the fields are equal in magnitude and opposite in direction.
First, in what regions will the fields be pointing in opposite directions? Then determine what condition must be satisfied for the magnitudes to be equal. Find the points in those regions where the condition is satisfied.
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
