Magnetic Force and Gravity in a Horizontal Wire Circuit
The discussion revolves around a physics problem involving a horizontal wire circuit in a magnetic field. The wire, oriented north-south, experiences a force when current flows through it due to the magnetic field running east-west. Participants clarify the application of the right-hand rule to determine the direction of the magnetic force, emphasizing that it is perpendicular to both the current and the magnetic field. Confusion arises regarding the interpretation of the magnetic field's direction, with participants correcting misconceptions about the force's orientation. Ultimately, the force acts downward, affecting the scale reading.
phyvamp
A straight wire (length Lcm, mass mg) lies horizontally on top of a sensitive scale. The wire is oriented so it runs north-south, and it is part of an electric circuit that includes a battery and an open switch. There is a uniform magnetic field everywhere, magnitude bT and running east to west. Suddenly the switch is closed, and current IA runs through the wire from north to south. Find N, the reading of the scale, in Newtons, after the switch is thrown. As usual, use: g = 9.803 m/s^2.
F=mg
dF=BIdL
I feel a little confused about the question where it stated "magnitude b T and running east to west" this is the direction of B? So according to right-hand rule, since I is from North to South, the direction of Force due to magnetic field will go outward? So does it will affect the reading of the scale? I only need to consider gravity ?
thank you for the help.
Try your right hand rule again. If the current is running N-S and B is pointing E-W, the force is perpendicular to both of those, so it is pointing in which direction??
right hand: thumb points to south(down) forefinger points to west (left) and the middle finger is inward, so the force is inward?
No. Think of it like a map laying on a table. N-S are one direction on the table, E-W are a perpendicular direction, but still in the plane of the table. So what direction is perpendicular to both of those?
right?
thank you for the explanation, this is exactly what I feel confused. In the question, it stated "magnitude bT and running east to west" I thought the direction of B is from E-W, in other words, it points to the right, but actually it is not. It is either inward or outward, right?
I still don't think you're getting it. Again, thinking of the map on the table, if the current is running N-S, and B is running E-W (i.e left to right), the cross product of these is downward, toward the floor. I don't know what you mean by 'inward' and 'outward' in this context.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
