longcatislong
- 12
Magnetic Force on Various Sides of Spinning Loop??
A horizontal uniform magnetic field of magnitude 0.4 T is oriented at an angle of = 65° relative to a line perpendicular to plane of a vertical, rectangular loop, as indicated in the figure. The loop has a height of 8 cm and a width of 15 cm. Each of the 1000 turns of wire in the loop carries a current of 0.22 A counterclockwise around it.
a link to the diagram: http://www.webassign.net/userimages/last-prob-diag-small.jpg?db=v4net&id=86188
(a) Find the size of the force (+ only) on each side of the loop:
top: ____N?
bottom: 2 N
left: ___N?
right:____N?
Fb=ILBsintheta (where theta is the angle between I and B)
I'm using Fb=ILBSsintheta, and found theta to be 25 degrees. For the force on the top side, I'm using the length of the top side, 15cm=.15m.
I=.22A
L=.15m
B=.4T
theta=25 degrees
So, I get Fb=(.22)(.25)(.4)(Sin25)=.005579
I've also tried using the length of the other side, but it's still wrong according to my online homework.
Anything will help! This assignment is due soon!
top: ____N?
bottom: 2 N
left: ___N?
right:____N?
I=.22A
L=.15m
B=.4T
theta=25 degrees
