Magnetic forces and particle of mass
The discussion revolves around calculating the expression qvB/m for a particle with a specified mass and charge in a uniform magnetic field. The initial attempt involved using the cross product of velocity and magnetic field to find acceleration. However, it was noted that the computed acceleration was not valid since the velocity was not perpendicular to the magnetic field at that moment. The key point is that the calculation must ensure that the velocity and magnetic field are perpendicular to accurately determine the magnitude of acceleration. The problem emphasizes the need to correctly assess the conditions under which the expression is evaluated.
vanitymdl
A particle with mass 1.81×10−3kg and a charge of 1.22×10−8C has, at a given instant, a velocity v =(3.00×104m/s)j^. produced by a uniform magnetic field B =(1.63T)i^+(0.980T)j^
Find the value of the expression qvB/m (the magnitude of a when v is perpendicular to B ), where q is the magnitude of the charge, v is the magnitude of the velocity, B is the magnitude of the magnetic field, and m is the mass of the particle.
qvB/m =_____________m/s2
Attempt to problem:
F = m*a = q*(v cross B)
a = q/m * (v cross B)
v cross B = (0i + 30000j m/s) cross (1.63i + 0.980j T) = 0 i + 0 j - 48900 k m/s*T
a = 1.22 * 10^-8 C / 1.81 * 10^-3 kg * (0i + 0j - 48900 k m/s*T) = 0i + 0j - 0.3296 k m/s^2
But it keeps saying that the problem does not depend on I,j,k
The question is asking for the magnitude.
The problem asks for a when v is perpendicular to B. But you have computed a at the moment when v = 3e4 j. v is then not perpendicular to B since v dot B ≠ 0.
EDITed last part of original post.
Likes 1 person
