Magnetic Fields in Zero Gravity: Do They Interact with Gravity?
  • Thread starter Thread starter Viper2838
    Gravity Magnetism
The discussion centers on the interaction between magnetic fields and gravity in a zero-gravity environment. Participants clarify that while gravity can influence magnetic fields in extreme conditions, such as near black holes, no measurable effect is expected on Earth. Classical physics suggests that gravity does not affect the magnitude or direction of magnetic fields under normal circumstances. General relativity introduces some interactions, as gravity can bend light, which is related to electromagnetism. Overall, the consensus is that significant effects would require much larger scales than those typically encountered.
Viper2838
Hello all,
My physics group is planning an experiment that involes the effects of magnets on fluid dynamiscs in a weighless enviroment. Unfortunately, we, and our advisor, are unsure if gravity has any effect upon a magnetic field. Anybody know?
thanks
If you are asking does gravity affect the magnitude and direction of a magnetic field as decribed by classical equations, then strictly speaking, I believe it does. BUT this would only be in cases of very high gravitational fields (like near black holes, etc...).
But on the earth, I would not expect any measurable effect.
In terms of classical equations there would be no effect at all. In general relativity there is (gravity bends light and light is, after all, electromagnatism).
What he said. :smile: I kludged my words.
thanks all, i kind of figured for any measureable effect to occur, things would have to be a much much larger scale.
