Magnetism: Solving Force Problem with qvB Equation
  • Thread starter Thread starter Axeman2k
    Magnetism
An electron moving at 2.0x10^6 m/s in a magnetic field experiences an upward force of 2.3x10^-12 N while traveling southward. The user applies the equation F=qvB to find the magnetic field, rearranging it to B=(qv)/F. However, the calculated value does not yield the expected result, prompting a reevaluation of the formula. A suggestion is made to pay attention to units throughout the calculations to avoid errors. The discussion emphasizes the importance of careful unit management in solving physics problems.
Axeman2k
I am currently working on a problem that states...
An electron experiences the greatest force as it travels 2.0x10^6 m/s in a magnetic field when it is moving southward. The force is upward and of magnitude 2.3x10^-12 N. What is the magnitude and direction of the magnetic field?
I started with the equation F=qvB and came out with B=(qv)/F since I am trying to find the magnitude of the magnetic field. That calculates to
B=((1.6x10^-19)(2x10^6))/(2.3x10^-12) but does not come out to a correct awnser. Is there anything I am doing wrong?
It should be F/qv. To catch mistakes like this, you should use units in your work, or at least keep them in mind.
oops, thanks for catching that
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
