Magnitude in force of two blocks connected by rope.
The discussion focuses on calculating the magnitude of force F and the tension in the rope connecting two blocks, where block 1 has a mass of 4.50 kg and block 2 has a mass of 9.00 kg. The blocks move upward a distance of 3.00 m in 5.00 s under the influence of force F. The correct calculations yield a tension of 1.08 N in the rope and a total force of 1.62 N acting on block 1. The effect of gravity, quantified as 9.80 m/s², must be considered alongside the calculated acceleration of 0.120 m/s² to determine the net forces accurately.
  • Understanding of Newton's Second Law (F=ma)
  • Basic concepts of kinematics, including acceleration and average velocity
  • Knowledge of gravitational force and its impact on mass
  • Familiarity with standard equations of motion for constant acceleration
  • Review the derivation of Newton's Second Law in various contexts
  • Learn about the equations of motion for constant acceleration
  • Study the effects of gravitational force on objects in motion
  • Explore tension in ropes and cables in physics problems
Students studying physics, particularly those focusing on mechanics and forces, as well as educators looking for examples of problem-solving in dynamics involving multiple objects.
asdehaan
Two blocks are connected by a rope F (Vertical in the drawing, with force F pulling on a rope, block 1 attached to that rope, then there ia another rope off the bottom of block 1 that attaches to block 2). The block starts from a rest and moves upward a distance of 3.00m in 5.00s while this force is being applied. The upper block (1) has a mass of 4.50kg and the lower block (2) has a mass of 9.00kg.
What is the magnitude of force F?
What is the tension in the rope connecting the blocks?
F=ma
Acceleration = dv/dt. Since V is increasing at a constant rate, Vav is the same as V. a is the slope of the line of V(t). So:
Vav(3.00m-0m)/(5.00s-0s)=(3/5)(m/s)=.600(m/s)
a=(.600m/s)/(5.00m/s)=.120m/s^2
The forces in block 2 -> T(rope)=m2a
=9.00kg*.120m/s^2
=1.08N
The forces in block 1 -> F=T(rope)+m1a
=1.08N+4.50kg*.120m/s^2
=1.62N
And the force in the rope should be 1.08N.
If this is wrong, please point me in the right direction. It seems like the force of gravity should have some kind of an effect here, but I haven't used it.
Do I need to add the acceleration of gravity to my acceleration above to get the force of gravity to cancel out? So 9.80m/s^2+.120m/s^2=9.92m/s^2?
Thanks
Welcome to PF!
Hi asdehaan! Welcome to PF! :smile:
Sorry, I don't understand what you're doing here :redface:
you are given t and s and u (or vi), and you want to find a …
so just use one of the standard constant acceleration equations. :smile:
Yeah it was late last night. I'm not sure what I was doing. ;) I got it all squared away with my teacher today. Thanks.
Btw - I was trying to calculate the acceleration from the average velocity.
  • · Replies 25 ·
  • · Replies 38 ·
  • · Replies 33 ·
  • · Replies 37 ·
