What is the Magnitude of the Dipole Moment in a Uniform Electric Field?
The discussion revolves around calculating the magnitude of the dipole moment P in a uniform electric field of 20 N/C. The potential energy U of the dipole is expressed as U = -p · E, and there is a suggestion to use the maximum potential energy at an angle of 180 degrees for calculations. The need for an integral is mentioned, but the user is unsure how to begin. A correction is noted regarding a factor of 10^-26 that was initially overlooked. The conversation emphasizes using the relationship between potential energy, dipole moment, and the electric field to find the solution.
nothingatall
A certain electric dipole is placed in a uniform electric field E of magnitude 20 N/C. Figure 22-59 gives the potential energy U of the dipole versus the angle θ between E and the dipole moment P. What is the magnitude of P?
U=p(dot)E
Somehow there is an integral needed to solve this but I don't know where to start. there is also a graph with this question.
i thought...
U=-\vec{p} \cdot \vec{E}
but idk if that really changes much.
It does, i was just forgetting to multiply it by the factor of 10^-26 hehe. Thanks.
can't you just take Us to be the maximum, and the angle of 180 to be the angle that corresponds to the maximum potential, and plug these into U=-pEcos(theta), along with the magnitude of E?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
