Magnitude of the field used for electron
The discussion revolves around calculating the magnetic field required for an electron to follow a circular path with the same radius as a proton in a magnetic field of 0.5 T. The relevant equation used is r = mv/qB, where the mass of the proton is significantly larger than that of the electron. The user initially calculated the radius for the proton and then applied the same equation to find the magnetic field for the electron, arriving at a value of 2.7 x 10^-4 T. It was noted that the charge of the proton is opposite to that of the electron, which affects the direction of the magnetic field. The conversation emphasizes the importance of correctly applying the principles of electromagnetism and the relationship between mass, charge, and magnetic fields.
flynostrich08
a proton is projected perpendicularly into a magnetic field that has a magnitude of .5 T. the field is then adjusted so that an electron will follow a circular path of the same radius when it is projected perpendicularly into the field with the same velocity that the proton had. What is the magnitude of the field used for the electron?
r=mv/qB
i basically used the above equation to solve for r but left v=1 since it is the same in both then used B=mv/qr and plugged in r and realized i just did the same thing so can someone please help explain what i have to do in detail since i am lost. Thanks for any help
It should help you knowing that the proton mass is 1836 times bigger than the electron mass (mp=1836me)
thanks i was looking at my book wrong so i ended up solving for r of the proton then took that and solved for B of the electron using the same equation and got 2.7x10^-4. did anyone else get that?
I got the same result but it has to be negative because of the charges (qp=-qe). That result is for the same radius (distance from the center) but in the opposite direction.
thanks for pointing that appreciate the help
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
