Magnitude & Direction of V Vector
In summary, the V vector is a mathematical representation of an object's speed and direction of motion. The magnitude of a V vector is the length of the vector, which can be calculated using the Pythagorean theorem. The direction of a V vector is represented by an angle measured counterclockwise from the positive x-axis, and can be represented using different notation systems. It is important to specify both the magnitude and direction of a V vector to fully describe an object's motion.
future_vet
169
If Vx = 6.80 units and vy = -7.40 units, determine the magnitude and direction of V-> (vector, the arrow is above the V).
and
Should we use the following:
V magnitude = √ ( Vx^2 + Vy ^2) = √ (6.80^2 + (-7.40)^2) = 10 units
and for the direction: tan θ = Vy/Vx = (-7.40)/6.80 = -1.1
θ= -47.4 degrees below the x axis.
Would this be correct?
Thanks!
Looks correct to me.
Thanks a lot!
What is the V vector?
The V vector, also known as the velocity vector, is a mathematical representation of an object's speed and direction of motion.
What is the magnitude of a V vector?
The magnitude of a V vector is the length of the vector, which represents the speed or magnitude of the object's motion.
How is the magnitude of a V vector calculated?
The magnitude of a V vector can be calculated using the Pythagorean theorem, where the square of the magnitude is equal to the sum of the squares of the vector's components (i.e. speed in the x-direction and speed in the y-direction).
What is the direction of a V vector?
The direction of a V vector is represented by an angle in relation to a reference axis. It can be measured in degrees or radians and is typically measured counterclockwise from the positive x-axis.
How is the direction of a V vector represented?
The direction of a V vector can be represented using various notation systems, such as unit vectors, polar coordinates, or direction angles. It is important to specify both the magnitude and direction of a V vector in order to fully describe the object's motion.
