Make sure electro does not fall
  • Thread starter Thread starter seto6
    Electro Fall
To prevent an electron from falling to the ground near the Earth's surface, the electric field E must counteract the gravitational force acting on the electron. The relationship is expressed as Fg = Eq, leading to the equation mg/q = E, where m is the mass of the electron and g is the acceleration due to gravity. The discussion clarifies that the Earth is typically considered negatively charged, which aligns with the downward direction of the electric field. Understanding this concept is crucial for solving related physics problems. The explanation provided resolves the initial confusion about the Earth's charge.
seto6
THIS IS NOT A HOME WORK QUESTION THIS AS FROM ANOTHER Tutorial
find the electric field E need to prevent an electron from falling down to ground, when close to surface of the earth.
i approached this question saying that take gravity into account and take Earth to be negatively charged.
then Fg=Eq then Fg/q=E...
mg/q=E
is this correct?
if not can you explain the reasoning please!
Looks good to me.
normally do we take Earth to be + or negative?
The electric field surrounding the Earth points downward. (The Earth is negatively charged.)
thanks that makes more sense now!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
