Making Eulers eqs. comply with Lagrange eqs.
The discussion revolves around the modeling of quadrocopters using Euler's equations of motion compared to Lagrange's equations. Participants explore the differences in results obtained from these two approaches, particularly focusing on the formulation of the Lagrangian and its implications in a rotating frame.
  • One participant notes that while using Euler's equations makes sense for modeling quadrocopters, their attempt to use Lagrange's equations yields different results, specifically a linearized version of Euler's equations when linearized around zero angular velocities.
  • Another participant emphasizes that the Lagrangian must be expressed in terms of generalized coordinates and velocities, suggesting that the current formulation may not meet this requirement.
  • There is a discussion about the relationship between the input torques and the Euler angles, indicating a potential connection between forces and coordinates in the context of the problem.
  • One participant expresses difficulty in identifying mistakes without seeing the specific formulas used in the Lagrangian formulation.
  • Another participant suggests that the Lagrangian should be set up in a holonomous basis, indicating that Cartesian coordinates of angular velocity may not be suitable for this context.
  • There is mention of algebraic methods to relate Cartesian components to Euler angles, with references to external resources and textbooks on analytical mechanics.
  • A participant reflects on the concept of rotation in a rotating coordinate system, questioning the nature of the relationship between the object and the coordinate system during rotation.
Participants do not appear to reach a consensus on the correct formulation of the Lagrangian or the conditions necessary for Lagrange's equations to apply in this scenario. Multiple viewpoints and approaches are presented, indicating ongoing debate and exploration of the topic.
There are indications of missing assumptions regarding the formulation of the Lagrangian, particularly in relation to generalized coordinates. The discussion also highlights the complexity of transitioning between different reference frames and the implications for modeling dynamics.
MechatronO
Lately when doing a simulation for a quadrocopters most reports I've come across regarding modeling use Eulers equation of motion. That makes sense, as the quadrocopter is a body rotating in 3 dimensions.
Then I tried to model the system using Lagrange equations instead but I don't get the same result. I wrote the Lagrangian as
L = T-U = T = 0.5*(Ixωx2 +Iyωy2+Izωz2 )
But applying Lagrange equations to L doesn't give Eulers equation of motions. Actually though, it gives the linearized version of Eulers, when linearized around the angular velocities zero.
Why is this? I must have missed some crucial condition that must be fulfiled for Lagrange equations to hold true? Did I get the expression for the lagrangian L wrong? Is it because Eulers model a continuous mass distribution, while Newton/Lagrange rather deal with a system of masses? I assumed the lagrangian to be in the rotating frame, as are Eulers equations in their standard version.
The Lagrangian L must be expressed in terms of generalized coordinates and generalized velocities. This is only I can answer on such a level of detailing
But we have three general forces that are the respective input torques for each axis, and three general coordinates that are the euler angles, right?
it is hard to find your mistake without formulas
You must set up your Lagrangian in terms of generalized coordinates and the corresponding generalized velocities, i.e., you always work in a holonomous basis on the tangent space of your manifold, but the Cartesian coordinates of the momentaneous angular velocity in the body-fixed system of reference, as used in Euler's equations, are not such holonomous coordinates.
For the rigid-body description you can use Euler angles in the Lagrangian formalism.
vanhees71: Hmm. Is there some way of seeing this algebraically?
You can evaluate the Cartesian components in terms of Euler angles. I can point only to my German mechanics manuscript, but it's in any textbook on analytical mechanics treating the spinning top:
It starts here (unprimed coordinates refer to the inertial space-fixed and primed ones to the non-inertial/rotating body-fixed reference frame)
http://theory.gsi.de/~vanhees/faq/mech/node74.html
The relations between Euler angles and Cartesian coordinates of the angular velocity is given at
http://theory.gsi.de/~vanhees/faq/mech/node78.html
The Euler angles are depicted here (note that the meaning of the angles in different textbooks differ!):
http://theory.gsi.de/~vanhees/faq/mech/node22.html
I follow the convention in
A. Sommerfeld, Lectures on Theoretical Physics, vol. 1 (Mechanics)
which has a very good treatment of the top (which is no surprise, because Sommerfeld wrote a comprehensive mathematical treatment of the spinning top together with Felix Klein).
there is a simple way to obtain formulas for angular velocity in terms of Euler angles. This way is based upon the addition theorem for angular velocities (without calculating of the matrices
Hmm. Food for thoughts.
I should try to understand the issue of rotation in a rotating coordinate system first. Because, if the coordinate system is rotating exactly the same as some solid object, the rotation of the object in this coordinate system must be zero. But, it seems like rotation like this is defined such that the object is making an infinitely small rotation before the coordinate system follows? So that the rotation of the coordinate system is always lagging behind an infinitely small angle? I can't see how this could happen otherwise. Am I on the right track?
  • · Replies 25 ·
  • · Replies 23 ·
