Marx generator can it be used to power something?
  • Thread starter Thread starter bmxrider2012
    Generator Power
A Marx generator is primarily used for generating high-voltage pulses and has practical applications in testing electrical insulation and simulating lightning strikes. While it can create impressive visual effects similar to a Tesla coil, its utility for powering devices is limited. The generator is not designed for continuous power supply but rather for short bursts of high voltage. Its main purpose is in research and industrial testing rather than everyday use. Overall, while it can be entertaining, its practical applications are specialized and not suitable for general power generation.
bmxrider2012
ok so i seen some videos on youtube where people show off their marx generator and make giant sparks with them but what i want to know is can you actually use it to power something
is there any practical application for a marx generator or is it just for fun like a tesla coil ?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
