Mass dropped onto vertical spring what is the max compression?
A mass of 0.5 kg is dropped from a height of 1.5 m onto an uncompressed vertical spring with a spring constant of 500 N/m. The maximum compression of the spring is calculated using energy conservation principles, specifically equating gravitational potential energy and spring potential energy. One participant arrived at a maximum compression of approximately 0.20 m, while another obtained a significantly higher value. Clarification on the variables used in the calculations was sought, particularly regarding the definitions of 'h' and 'h_0'. The correct approach confirms that the initial calculations were accurate.
MathHelpa
A mass m = 0.5 kg is dropped from a height of 1.5m above the end of an uncompressed vertical spring with k = 500 N/m. What is the maximum compression of the spring?
f_sp = -kx
W_sp = 1/2 kx^2
W_nc = ΔK + ΔU
K = 1/2 mv^2
U = mgh
W = Fdcos∅
p = mv
My friend and me were in different groups and they did the problem differently and came to a different answer. We set up ours as mg(h_0 + Δx) = 1/2hΔx^2 and came to a answer of .18 and rounded to .20 for Δx. My friend got much higher number so I was wondering what the answer really was and how to do it correctly if we are wrong.
What are 'h' and 'h_0' in you formula?
f_sp = -kx
W_sp = 1/2 kx^2
W_nc = ΔK + ΔU
K = 1/2 mv^2
U = mgh
W = Fdcos∅
p = mv
You meant 1/2 kdx^2...
Your solution is correct.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
