Mass on a spring Please respond ly
  • Thread starter Thread starter saltrock
    Mass Spring
A mass attached to a spring oscillates due to the interplay between gravitational force and spring tension. Initially, when the mass is attached, the weight (mg) exceeds the tension (T), causing it to move downward. As it descends, tension increases and eventually surpasses the weight, reversing the motion. This cycle continues, driven by the relationship between force, displacement, and energy conversion between kinetic and potential forms. The oscillation persists until energy is dissipated through damping effects, such as fluid resistance.
saltrock
Mass on a spring!Please respond urgently !
When the mass is attached on one end of the string , it oscillates.with refrence to the tension and weight,explain why it oscillates.
ans: *when the mass it attached then mg> T so it goes down
* when it goes down then T>mg so it goes up and repeats the same process...
please help me write a good answer for this.
it won't oscillate until you start it with an input of energy and then it vibrates until energy dissipated to the surroundings, e.g. by damping (due to fluid resistance etc)
Just state that acceleration is directly proportional to displacement and is always towards an equiilbrium point.
Not sure if this helps tho.
I think what you were getting at here is also good to add. Because F_{spring}=-kx, where k is the spring constant and x is the displacement from equilibrium, the force exerted by the spring on the mass increases as the spring is compressed or extended. Also consider that elastic potential energy (due to the spring) and kinetic energy are constantly interconverted during the oscillations, with max kinetic energy (and therefore max velocity) occurring when the mass passes the equilibrium point, because there elastic potential energy is zero.
