Find Speed of Block Dropped on Spring: Mass, Height, Compression
  • Thread starter Thread starter grouchy
    Mass Spring
The discussion focuses on calculating the speed of a 9.3 kg block dropped from a height of 800 cm onto a spring with a spring constant of 1086 N/m, which compresses by 50 cm. The transformation of energy is key, where gravitational potential energy (Eg) converts to kinetic energy (Ek) as the block falls, and then to elastic potential energy (Ee) upon spring compression. The user expresses confusion about applying the correct equations for energy transformation. They attempted to use the equation 1/2mv^2 = 1/2kx^2 but found it incorrect. Understanding the energy transformation process is essential for solving the problem accurately.
grouchy
A 9.3 kg block is dropped onto a spring of spring constant 1086 N/m from a height of 800 cm. When the block is momentarily at rest, the spring has been compressed by 50 cm. Find the speed of the block when the compression of the spring is 10 cm. The acceleration of gravity is 9.81 m/s^2. Answer in units of m/s.
Equations...
1/2kx^2
k = 1/2mv^2
u = mgh
my problem is I don't understand which equations to use in which situations,..
This is simply a transformation of energy question.
Right at the start before the block is dropped, only gravitation potential energy (Eg) is present. Then all of the Eg is turned into kinetic energy (Ek) as the block falls. Just before the block hits the spring, all of the Eg is turned into Ek. Then the block impacts the spring and compressing it, turning Ek into Elastic potential energy (Ee).
Therefore, it would:
Eg-->Ek-->Ee
Using this transformation method, it would be very simple to solve this.
If I wasn't very familiar with the whole transformation of energy...how would I do this?
I tried 1/2mv^2 = 1/2kx^2 and it comes out wrong..
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
