Mass sliding down surface of a sphere
A small mass slides down a frictionless spherical surface, and the problem requires finding its speed at the point of losing contact, where the velocity makes a 48.2-degree angle with the vertical. The conservation of energy principle is suggested as a method for solving the problem, using the equation PE1 = PE2 + KE. An initial attempt to calculate the speed resulted in an incorrect value of 0.57 m/s, which does not match any of the provided answer choices. A reminder to consider gravitational acceleration (9.8 m/s²) and to carefully read the question regarding the angle was given. The discussion emphasizes the importance of applying the correct equations and understanding the problem's parameters.
Victorzaroni
A small mass m slides down from rest at the top of a frictionless spherical surface of radius R=.5 meters. What is the speed of the particle at position x where it loses contact with the surface, and velocity makes an angle of θ=48.2 with the vertical?
The answer choices are:
(A) 1.28 m/s
(B) 1.82 m/s
(C) 1.93 m/s
(D) 2.36 m/s
(E) 2.58 m/s
Conservation of Energy?
I thought maybe start with PE1=PE2+KE, where h=2r, and then find the cosine component of the height when velocity is at that angle, to do: mg(2r)=(1/2)mv2+mg((cos48.2)+R), but that didn't work. I got .57, which is not even close to any of the choices.
Hi Victorzaroni! :smile:
I think you missed out the 9.8 :wink:
(also, read the question carefully about the angle)
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
