slydg895
- 6
- 0
The condition ∑ Fi = 0 is not sufficient to assure that a rigid body is in equilibrium.
TrueFalse
2.A quantity that expresses how a force can create an angular acceleration is called
a. moment of inertia
b. angular influence
c. angular energy
d. angular momentum
e. torque
3.
According to the lab manual, clockwise torques are taken as Fill in the Blank 01 (positive or negative) and counterclockwise torques are taken as Fill in the Blank 02 (positive or negative).
4.
Calculate the lever arm of F as measured from the point O. The angle is θ = 42o and the distance r = 1.5 m. Express the answer in meters.
Answer
Save Answer
5.Given the situation in the figure below. The mass m1 is 0.55 kg and it is located at x1 = 30 cm. The pivot point is represented by the solid triangle located at x = 45 cm. The mass of the meter stick (mms = 0.40 kg) is located at its geometric center, xms = 50 cm. The mass m2 is 0.35 kg and it is located at x2 = 80 cm. Calculate the net torque (in N⋅m with the proper sign) due to these three weights. Use g = 9.8 m/s2.
6. The apparatus described in Question 5 is in equilibrium.
TrueFalse
7.Suppose that a meter stick is balanced at its center. A 0.17-kg is positioned at 31 cm from the left end of the meter stick. Where should a 0.26 kg mass be placed to balance the 0.17 kg mass? Express your answer in terms of the position (in cm) of the 0.26-kg mass as measured from the left end of the meter stick.
Hey guys my proffesor gave us some questions he reccomended to attempt doing before tommorow's lab. I have finished them but we do not have answers so i was wondering if you guys could tell me if i was doing anything wrong.
Here are my answers:
1.False
2.Angular momemtum
3.positive(counterclockwise) and negative (clockwise) used right hand rule
4. I got -.599 by using rcos(theta) --i really don't know how to do this one
5.-.098 using T=Fr
6.False
7.63cm
Any help appreciated thanks a lot guys!
