Mastering Laurent Series Expansion: A Layman's Guide
6 replies · 3K views
j-lee00
In attachment
I break into partial fractions, then get stuck. Please help me in layman terms
f(z) = -1/3[3(z+1)] + 4/3[z+4]
Now I am stuck.
Hi!
I will help you with a full list of steps for one of the parts:
[tex] <br /> \frac{4}{3(z + 4)} = \frac{4}{3(4(\frac{z}{4} + 1))} = \frac{1}{3(\frac{z}{4} + 1)} = \frac{1}{3(1 + \frac{z}{4})} = \frac{1}{3}\cdot \frac{1}{(1 + \frac{z}{4})} = \frac{1}{3}\cdot\frac{1}{(1-(-\frac{z}{4}))} = \frac{1}{3}\left ( 1 + (-\frac{z}{4}) + (-\frac{z}{4})^{2} + (-\frac{z}{4})^{3} +\cdots \right ) = <br /> [/tex]
[tex] <br /> = \frac{1}{3}\left ( 1 - \frac{z}{4} + \frac{z^{2}}{4^{2}} - \frac{z^{3}}{4^{3}} +\cdots \right ) = \frac{1}{3} - \frac{z}{3\cdot 4} + \frac{z^{2}}{3\cdot 4^{2}} - \frac{z^{3}}{3\cdot 4^{3}} +\cdots[/tex]
Remember that for a given geometric series to converge |x| has to be less than 1. which in your case means:
[tex] \left |\frac{z}{4} \right |<1[/tex]I hope you will understand all the steps otherwise do ask.
P.S. I used the sum of the geometric series (which is also the Taylor and Laurent series): 1/(1 - x) = 1 + x + x^2 + x^3 + ...
|x|<1
Thanks for your help.
With the expansion that you made, how does this differ to the taylor expansion? or it the same?
Are the negative powers of the Laurent expansion only as big as the largest pole?
What do you mean by "largest pole"?
Note that
[tex]\frac{4}{3(z + 4)} = \frac{1}{3} \left( 1 - \frac{z}{4} + \frac{z^2}{4^2} - \frac{z^3}{4^3} + \cdots \right)[/tex]
has a pole at z=-4 yet no negative-power terms. The Laurent series about z=0 of the function for |z|>4 is
[tex]\frac{4}{3(z + 4)} = \frac{4}{3z}\left( 1 - \frac{4}{z} + \frac{4^2}{z^2} - \frac{4^3}{z^3} + \cdots \right)[/tex]
has an infinite number of negative-power terms.
What you wrote clarified my problem. tks
