What type of mechanism would be best for propelling a 1400 pound cart?
In summary, the conversation discusses the objective of propelling a 1400 pound cart using energy collected from loading the part onto the cart. The current idea is to use a plunger that spins a mechanism to wind a spring, but there are concerns about the size of the spring. The type of mechanism recommended would depend on factors such as the distance and speed the cart needs to travel, as well as the control needed for motion. Storing energy in a spring compressed by the weight of the part is favored. Calculations can be done to determine the necessary amount of energy and compression distance for the spring. Other considerations include efficiency, control, and safety.
trailcarnage
Hello!
I am a 1st time poster here who needs some fresh ideas. After lurking around several forum, I think this is the place to get them.
Objective:
Propel a cart carrying a 1400 pound part using energy collected from action of loading the part onto the cart.
Current idea:
I am picturing a plunger that is depressed by the part. The plunger spins the mechanism that winds the spring. I fear how large the spring would need to be though.
What kind of mechanism would you recommend?
It will depend on how far and fast the cart has to be propelled (and if its up of down hill), and what kind of control you will need to have of the motion (turning, stopping and starting again). I do like the idea of storing energy in a spring that is compressed/extended using the weight of the part being loaded.
The cart needs to travel around 20' at a low speed, 4-6"/sec. It will need to turn, stop, restart and reverse direction.
Well, based on those numbers you can calculate how much energy needs to be stored in the spring in terms of kinetic energy required to get the cart moving. Then, knowing how much energy you need, you can figure out how far the spring will have to be compressed, and therefore how far your plungers travel will be.
Things like efficiency will definitely come into play, as well as determining things like will it be automatic or manually controlled, and safety issues of a 1400+lb cart driving itself around.
FAQ: What type of mechanism would be best for propelling a 1400 pound cart?
What is a material handling device?
A material handling device is any equipment or tool used to move, store, or transport materials within a workplace or industrial setting. It can include items such as forklifts, conveyor belts, pallet jacks, and cranes.
Why is material handling important?
Efficient material handling is crucial for the smooth operation of any workplace. It helps to reduce workplace injuries, increase productivity, and minimize material damage or loss. It also plays a key role in streamlining supply chain processes and reducing overall operational costs.
What are the different types of material handling devices?
There are several types of material handling devices, and they can be categorized into four main groups: storage equipment, engineered systems, industrial trucks, and bulk material handling equipment. Each type serves a specific purpose and may be suitable for different industries or materials.
How do you choose the right material handling device?
When choosing a material handling device, it is essential to consider factors such as the type and size of materials being handled, the layout of the workplace, and the specific needs and requirements of the operation. It is also crucial to ensure that the device complies with safety regulations and is suitable for the workers who will be using it.
What are the safety precautions for using material handling devices?
Safety is a top priority when using material handling devices. Some general precautions include proper training for workers, regular maintenance and inspections of equipment, and following safety guidelines and protocols. It is also essential to provide appropriate personal protective equipment and ensure that workers are aware of potential hazards and how to handle them safely.
