How effective are materials for good wear in a dry-running air motor?
  • Thread starter Thread starter Mike_In_Plano
    Materials
The discussion revolves around the feasibility of constructing a dry-running air motor designed for 25,000 hours at 5-20k RPM, focusing on material selection to minimize wear. Participants suggest various combinations of materials for gears and endplates, including steel, Delrin, and ceramic, emphasizing the importance of compression to reduce air leakage. Concerns are raised about the high speeds and the potential for melting plastic bearings, with alternative suggestions like using unlubricated ceramic ball bearings or magnetic bearings. The idea of employing aerostatic bearings is also explored as a potential solution for maintaining performance without excessive wear. Overall, the conversation highlights the complexities of material choice and design in achieving durability in high-speed applications.
Mike_In_Plano
Hello,
I'm puzzling over the likelihood of building a dry-running air motor for 25khrs @5-20kRPM.
I'm considering whether a small gear pump arrangement would doe the job - it only needs to output 6 shaft watts, but I'm concerned about wear.
Standard gears are avalable in steel and delrin, and with a bit of searching, in ceramic. I'm wondering what would be a good combination of materials between the endplates and gear. It seems that the endplates would have to be under a bit of compression to ensure that the air leakage doesn't become excessive over time.
Does this seem a reasonable conjecture?
It also seems the endplates would be a complimentary material:
Steel vs teflon loaded delrin plate
Ceramic vs teflon loaded delrin plate
Delrin vs Hard steel
Finally, how would one go about accelerating wear testing?
Well, I guess that wraps it up (and then some :)
Best Regards,
Mike
The bearing material makers often have data sheets showing wear rates. Tho it can depend on speed as well as pressure and countersurface material. They may just show a few data points and leave you to guess the rest.
I see Dupont has a lot of leaflets online about Delrin's wear characteristics.
I'm kind of amazed at running a gear pump so fast. You can't use a centrifugal pump? You'd avoid a lot of the sliding sealing surfaces.
You have no single chance with a dry plastic bearing at 25,000/min. It would melt.
In case this is a matter of vapour pressure, some lubricants have an extremely low one. Use with plain bearings of sintered metal.
You may try with unlubricated ceramic ball bearings.
An other direction is magnetic bearings.
Or could you maybe use the pressurized air in a set of "aerostatic" bearings? Similar to hydrostatic ones, with big leaks, connected in series with your engine?
Thinking again at the aerostatic bearing...
Let's imagine your engine can be a centripetal turbine (you didn't mention that). Then you might inject the air at the periphery, use some of its energy contents to rotate the turbine, and let the air exit through the shaft at the bearings, where the remnant pressure gives lifting and centring force.
Maybe it doesn't fit your needs, but it's puzzling.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
