Math Challenge - August 2020
104 replies · 20K views
fresh_42 said:
Summary:: functional analysis, operator theory, topology, measure theory, calculus
Authors: Math_QED (MQ), Infrared (IR), Wrobel (WR), fresh_42 (FR).
8. Let F be a meromorphic function (holomorphic up to isolated poles) in C with the following properties:
(1) F is holomorphic (complex differentiable) in the half plane H(0)={z∈C:ℜ(z)>0}.
(2) zF(z)=F(z+1).
(3) F is bounded in the strip {z∈C:1≤ℜ(z)≤2}.
Show that F(z)=F(1)Γ(z). (FR)
By (3) ##\exists M :| F(x+iy) |< M,\forall x\in \left[ 1,2\right]## and in particular ## | F(1) | <M##, also by (2) ##F(z)=\tfrac{1}{z} F(z+1)## and hence F(z) is bounded in the half-plane ##H(0)##. Also by (2) ##\lim_{z\to 0} F(z)=\lim_{z\to 0}\tfrac{1}{z}F(z+1)=F(1)\lim_{z\to 0}\tfrac{1}{z}=\infty## but ##\lim_{z\to 0}zF(z)=\lim_{z\to 0}F(z+1)=F(1)## so ##z=0## is a simple pole of ##F(z)## and continuing by (2) we see that ##a_k=-k,\forall k\in\mathbb{N}## are simple poles of ##F(z)##.
Define ##f(z):=\tfrac{1}{F(z+1)}## so that ##f(z)## is entire, then by the Weierstrass' Factor Theorem
$$f(z)=f(0)e^{\tfrac{f(0)}{f^\prime (0)}z}\prod_{k=1}^\infty \left\{\left(1-\tfrac{z}{a_k}\right)e^{\tfrac{z}{a_k}}\right\}\quad \text{(eqn 1)}$$
and we have from the definition of ##f(z)## that ##f(0)=\tfrac{1}{F(1)}## and that ##f^\prime (0) =-\tfrac{1}{\left[ F^\prime (1)\right] ^2}## substituting all known values into (eqn 1) we get
$$\tfrac{1}{zF(z)}=\tfrac{1}{F(z+1)}=\tfrac{1}{F(1)}e^{-\tfrac{F(1)}{\left[ F^\prime (1)\right] ^2}z}\prod_{k=1}^\infty \left\{\left(1+\tfrac{z}{k}\right)e^{-\tfrac{z}{k}}\right\}$$
multiply by ##z## on both sides
$$\tfrac{1}{F(z)}=\tfrac{z}{F(1)}e^{-\tfrac{F(1)}{\left[ F^\prime (1)\right] ^2}z}\prod_{k=1}^\infty \left\{\left(1+\tfrac{z}{k}\right)e^{-\tfrac{z}{k}}\right\}\quad (eqn 2)$$
set ##z=1## in the above
$$\tfrac{1}{F(1)}=\tfrac{1}{F(1)}e^{-\tfrac{F(1)}{\left[ F^\prime (1)\right] ^2}}\prod_{k=1}^\infty \left\{\left(1+\tfrac{1}{k}\right)e^{-\tfrac{1}{k}}\right\}$$
do some algebra to get
$$\tfrac{F(1)}{\left[ F^\prime (1)\right] ^2}=\lim_{N\to\infty}\sum_{k=1}^N\left[\log \left(1+\tfrac{1}{k}\right)-\tfrac{1}{k}\right]=-\gamma$$
by the definition of Euler's constant ##\gamma##, substitute this into (eqn 2) and compare to the Weierstrass product definition of the Gamma function and we have arrived at the required result.
Edit: See below for my next post for a more well explained proof.
Oh brother, this simply connected business for [itex]\mathbb C^*[/itex] is simply not necessary. Let's go again.
Suppose [itex]g:\mathbb C^* \to \mathbb C[/itex] is continuous with [itex]e^{g(z)} \equiv z[/itex]. Then [itex]g[/itex] is holomorphic, because the exponential map is holomorphic and
[tex] \lim _{z\to z_0} \frac{g(z) - g(z_0)}{z-z_0} = \lim _{g(z)\to g(z_0)} \frac{g(z)-g(z_0)}{e^{g(z)} - e^{g(z_0)}}.[/tex]
By differentiating we get [itex]1 = g'(z) e^{g(z)} = zg'(z)[/itex], which implies [itex]g'(z) = \frac{1}{z}[/itex] on [itex]\mathbb C^*[/itex]. But now by Cauchy's integral theorem, we get
[tex] 0 = \oint _{|z|=1} g'(z) dz = \oint_{|z|=1} \frac{1}{z} dz = 2i\pi.[/tex]
Thus, such a [itex]g[/itex] cannot exist.
Maybe I'm hunting a fly with a 50 cal rifle with armor-piercing rounds..
Ok, I see "some algebra" but could you at least elaborate the last lines? Especially as you nowhere mentioned which definition of the Gamma function you used. I have the impression that it takes me more effort to make your proof readable than it takes to give another one. Also Weierstrass needed a bit more explanation. I doubt that an average member can understand how you applied it to what.
edit begins here:
by the definition of Euler's constant ##\gamma##, substitute this into (eqn 2) and invert to get
$$\begin{gathered} \boxed{ F(z)=F(1)\cdot\tfrac{1}{z} e^{-\gamma z}\prod_{k=1}^\infty \left\{\left(1+\tfrac{z}{k}\right) ^{-1} e^{\tfrac{z}{k}}\right\} \\ =F(1)\cdot \Gamma (z) } \\ \end{gathered}$$
since the Weierstrass' product definition of the Gamma function is
$$\Gamma (z) =\tfrac{1}{z} e^{-\gamma z}\prod_{k=1}^\infty \left\{\left(1+\tfrac{z}{k}\right) ^{-1} e^{\tfrac{z}{k}}\right\} $$
Maybe I'm misunderstanding the problem, but if we're only worried about continuity (and not differentiability), can't we just do something simple? I just built a parallelogram and let ##f## and ##g## take paths along opposite sides:
Let ##f(\frac{3}{2})=\frac{3}{2}, g(\frac{3}{2})=\frac{3}{2}, f(\frac{1}{2})=\frac{1}{2}, g(\frac{1}{2})=\frac{1}{2}##. Notice that ##\frac{1}{2}x+\frac{3}{4}## and ##2x-\frac{3}{2}## both go through ##(\frac{3}{2},\frac{3}{2})##, and ##\frac{1}{2}x+\frac{1}{4}## and ##2x-\frac{1}{2}## both go through ##(\frac{1}{2},\frac{1}{2})##. We see that ##2x-\frac{1}{2}## intersects ##\frac{1}{2}x+\frac{3}{4}## at ##(\frac{5}{6},\frac{7}{6})##, and ##2x-\frac{3}{2}## intersects ##\frac{1}{2}x+\frac{1}{4}## at ##(\frac{7}{6},\frac{5}{6})##.
So now we just define:
$$f(x)=\begin{cases}
x &\text{if } 0\leq x < \frac{1}{2} \text{ or }\frac{1}{2} \leq x \leq 2\\
2x-\frac{1}{2} & \text{if } \frac{1}{2} \leq x < \frac{5}{6} \\
\frac{1}{2}x+\frac{3}{4}& \text{if } \frac{5}{6} \leq x < \frac{3}{2} \\
\end{cases}
and
$$g(x)=\begin{cases}
\frac{1}{2}x+\frac{1}{4}& \text{if } \frac{1}{2} \leq x < \frac{7}{6} \\
2x-\frac{3}{2} & \text{if } \frac{7}{6} \leq x < \frac{3}{2} \\
\end{cases}
Let [itex]K\subseteq \mathbb C[/itex] be non-empty compact. Suppose [itex]\{\gamma_n \in K \mid n\in\mathbb N\} \subseteq K[/itex] is dense in [itex]K\ \[/itex] ([itex]\mathbb C[/itex] is separable). Let [itex]D : e_n\mapsto \gamma_ne_n[/itex] be a diagonal operator (in the infinite case [itex]H\cong \mathbb C^\omega[/itex], otherwise [itex]H\cong \mathbb C^N[/itex]).
For any [itex]n\in\mathbb N[/itex] we have [itex]\gamma_n\in\sigma (D)[/itex], because [itex]D-\gamma_n\mathrm{id}[/itex] is not injective. If we look at the kernel, we have
[tex] \sum \lambda _k(D-z_n\mathrm{id})(e_k) = \sum _{k\neq n} (\lambda _k\gamma_k - \gamma _n)e_k + (\lambda_n -1)\gamma _n e_n = 0.[/tex]
We can clearly see [itex]\lambda _k \equiv 0[/itex] is not forced.
Since [itex]\sigma (D)[/itex] is closed, we also have [itex]K\subseteq \sigma (D)[/itex]. On the other hand, suppose [itex]\lambda\notin K[/itex]. Then
[tex]F \left ( \sum \lambda _ke_k\right ) := \sum\frac{\lambda _k}{\gamma _k-\lambda}e_k[/tex]
is the inverse of [itex]D-\lambda \mathrm{id}[/itex], thus [itex]\lambda\notin \sigma (D)[/itex]. Indeed, we can check for basis elements. We have
[tex] (F \circ (D-\lambda \mathrm{id}))(e_k) = F((\gamma _k-\lambda)e_k) = \frac{\gamma _k-\lambda}{\gamma _k-\lambda}e_k = e_k[/tex]
and
[tex] ((D-\lambda \mathrm{id}) \circ F)(e_k) = (D-\lambda \mathrm{id}) \left ( \frac{1}{\gamma _k-\lambda}e_k \right ) = e_k.[/tex]
Altogether [itex]\sigma (D) = K[/itex].
[tex]F \left ( \sum \lambda _ke_k\right ) := \frac{\lambda _k}{\gamma _k-\lambda}e_k[/tex]
and
Seems to work! Working with diagonal operators was also what I had in mind. Here is a more sophisticated approach using the theory of ##C^*##-algebras:
Consider the ##C^*##-algebra ##C(K)##. Then the inclusion ##i: K \to \Bbb{C}## has spectrum ##K##. Next, choose a Hilbert space ##H## and an injective ##*##-homomorphism ##\varphi: C(K) \to B(H)## (GNS-construction). Then ##\varphi(i)## is a bounded operator on ##H## with spectrum ##K##.
I will look at the other solution attempt soon.
@TeethWhitener If I take ##a=3/2## and ##b=1/2## in your example, then ##f(3/2)-f(1/2)=1## and ##g(3/2)-g(1/2)=1## are both integers.
Suppose [itex]V/W[/itex] is complete. Let [itex]x_n\in V,\ n\in\mathbb N,[/itex] be a Cauchy sequence. Let [itex]\pi :V\to V/W[/itex] be the projection, then [itex]\pi (x_n),\ n\in\mathbb N,[/itex] is Cauchy in [itex]V/W[/itex]. For some [itex]x\in V[/itex] we have [itex]\pi (x_n) \xrightarrow[]{}\pi (x)[/itex]. By definition of infimum pick [itex]z_n\in V[/itex] such that [itex]\|x_n-x-z_n\| \leq \|\pi (x_n-x)\| + \frac{1}{n},\ n\in\mathbb N.[/itex] Then [itex]\|x_n-(x+z_n)\| \to 0[/itex]. So we would have [itex]x_n \to x+\lim z_n[/itex]. This is justified, because by triangle equality
[tex] \|z_n-z_m\| \leq \|x_n-x-z_n\| + \|x_n-x_m\| + \|x_m-x-z_m\| \xrightarrow[m,n\to\infty]{}0.[/tex]
I must have misread the question then. Are you looking for a proof that it's true for all ##f,g## given the problem constraints? I thought the question was just asking for an example.
Given arbitrary continuous maps [itex]f,g[/itex] on [itex][0,2][/itex] we are to show such [itex]a\neq b[/itex] exist. I'm thinking Intermediate value theorem might help. Not sure, right now.
For every [itex]x\in\mathbb R[/itex] we have [itex]\mathbb P\{X\leq x\}\in \{0,1\}[/itex]. Let [itex]F[/itex] be the distribution function for [itex]X[/itex]. [itex]F[/itex] is right continuous and we have [itex]\lim _{x\to\infty} F(x) = 1[/itex] and [itex]\lim _{x\to -\infty}F(x) = 0[/itex]. This implies there exists [itex]c\in\mathbb R[/itex] such that [itex]F = I_{[c,\infty]}[/itex]. Now [itex]\mathbb P\{X<c\} = F(c-) = 0[/itex], therefore [itex]X=c[/itex] a.s.
We have [itex]\mathbb P\{X\leq x\} \in\{0,1\}[/itex] for every [itex]x\in\mathbb R[/itex]. One readily verifies [itex]X[/itex] is independent of itself. Put [itex]c:= \inf \{x\in\mathbb R \mid X\leq x\}[/itex]. It is finite, because [itex]\lim _{x\to \infty} \mathbb P\{X\leq x\} = 1[/itex], therefore for sufficiently large [itex]x_0[/itex] we have [itex]\mathbb P\{X\leq x_0\}=1[/itex]. By Kolmogorov's 0-1 law [itex]\mathbb P\{X=c\}=1[/itex].
Since [itex]X[/itex] is almost surely constant, the probability it takes any other value is zero, hence its variance is zero. Therefore [itex]\mathbb E(X-\mathbb E(X))^2 = 0[/itex] implies [itex]X=\mathbb E(X)[/itex] a.s. The first moment exists, because variance is finite.
nuuskur said:
.. by triangle equality
Triangle equality 😂 I meant triangle inequality.
9. Show that there exists no continuous function g:C∖{0}→C such that eg(z)=z for all z∈C∖{0} (i.e. there is no continuous logarithm on C∖{0}). (MQ)
(Corrected version, credits go to @PeroK for pointing out and solving the original problem.)
I beg to differ: A Course of Modern Analysis, 3rd ed. Whittaker & Watson pg 589 (heading A6) says ##\log z = \Log |z| + i \arg z## is a continuous multi-valued function of ##z## since ##|z|## is a continuous function of ##z##.
I suspect you can make log continuous by taking the domain to be a set of complex planes disconnected at the branch cuts.
These are, of course, Riemann surfaces.
In any case it's ##\arg z## that is discontinuous.
We can kill a fly with a fly swatter. Don't need the rifle.
Suppose [itex]g:\mathbb C^* \to\mathbb C[/itex] is continuous and satisfies the identity [itex]e^{g(z)} = z[/itex]. Since [itex]g[/itex] is right inverse to [itex]\exp[/itex], it is injective, thus [itex]g(\mathbb C^*) \cong \mathbb C^*[/itex]. But now [itex]\exp[/itex] is forced to be injective on [itex]\mathbb C^*[/itex]. Indeed, for any [itex]u,v\neq 0[/itex] we have
[tex]e^u = e^v \Leftrightarrow e^{g(z)} = e^{g(w)} \Leftrightarrow z=w \Rightarrow u=v.[/tex]
But that's impossible.
@nuuskur Where did you use continuity (this is definitely a necessary condition)? Anyway, you seem to be claiming that ##g## is surjective in saying ##g(\mathbb{C}^*)=\mathbb{C}^*##. How do you know this? If you only mean that ##g## gives a bijection from ##\mathbb{C}^*## to its image, then how are you writing ##u=g(z), v=g(w)##?
PeroK said:
If we try to make ##\beta## continuous, then without loss of generality we can take ##\beta(0) = 0##, hence ##\beta = \theta## and we get a discontinuity at ##\theta = 0##. More generally, for any ##\phi## we could could take ##\beta(\phi) = \phi + 2n\pi## and get the discontinuous branch cut at ##\theta = \phi##.
Hmm, I need a little more details here. Explain why the discontinuities arise. I find your argument a bit too handwavy.
Continuity is implicit. I'm working in the category with continuous maps. No, [itex]g[/itex] is injective, therefore it's an isomorphism onto its image.
Which part of your argument fails if ##g## is not required to be continuous?
Please explain this line.
What are ##z## and ##w## in relation to ##u## and ##v##? It looks to me like you're assuming that ##g## is surjective here (by saying that you can write ##u=g(z), v=g(w)##)
You really need that ##g(\Bbb{C}^*) = \Bbb{C}^*## for your argument to work. Also, when using the symbol ##\cong##, explain what you mean with the symbol. I assume that you mean isomorphism in the category of continuous maps, but how are you even sure the inverse on the image is continuous as well?
Explain this line.
Effectively it boils down to the discontinuity of ##\arg z##. I thought that was trivial and well established!
  • Haha
Ok, here are the details. Firstly, since [itex]g[/itex] is injective, it means [itex]g(\mathbb C^*) \cong \mathbb C^*[/itex] as sets. That means any [itex]u\neq 0[/itex] can be written uniquely as [itex]u=g(z)[/itex]. But we also have a homemorphism with the obvious choice ( this is forced, really) [itex]f(g(z)) := z,\ z\neq 0[/itex]. For continuity of [itex]f:g(\mathbb C^*) \to \mathbb C^*[/itex] suppose [itex]g(z_n) \to g(z)[/itex], then continuity of exponential map implies [itex]e^{g(z_n)} \to e^{g(z)}[/itex] which by assumption is the same as [itex]z_n\to z[/itex] so [itex]f[/itex] is continuous.
What fails if [itex]g[/itex] is not continuous: it wouldn't be a morphism in the category with continuous maps, so the above won't apply.
Math_QED said:
Explain this line.
By definition of limit. As [itex]x\to -\infty[/itex] we must have [itex]A>0[/itex] such that [itex]x\leq -A[/itex] implies [itex]F(x) = \mathbb P\{X\leq x\}=0[/itex]. Since such [itex]A[/itex] are bounded from below, take the infimum i.e [itex]c := \inf \{x\in\mathbb R \mid X\leq x\}[/itex]. Now, whatever happens for [itex]x>c[/itex] must occur with probability [itex]1[/itex] (otherwise [itex]c[/itex] wouldn't be the infimum). There can be no in-betweens so [itex]F = I_{[c,\infty]}[/itex] is forced due to right continuity of [itex]F[/itex] i.e [itex]F(c+) = 1[/itex].
Suffices to show [itex]C(f) = \{x\in X \mid f\text{ is continuous at }x\}[/itex] is a Borel set, it can also be empty. Then [itex]C(f)^c = D(f)[/itex] is a Borel set. Let's chase epsilons from the definition of continuity. [itex]f[/itex] is continuous at [itex]x\in X[/itex] if and only if
[tex] \forall n\in\mathbb N,\ \exists \delta >0,\ \forall z\in X,\quad z\in B(x,\delta) \Rightarrow f(z) \in B\left (f(x), n^{-1}\right ).[/tex]
In other words we have [itex]\{x\}= \bigcap _{n\in\mathbb N} \{U\subseteq X \mid x\in U,\ U\text{ is open and }f(U) \subseteq B(f(x), n^{-1}) \}[/itex]. Do this for all points of continuity, then we have the [itex]G_\delta[/itex] set
[tex] \bigcap _{n\in\mathbb N} \bigcup \left\{ U\subseteq X \mid U\text{ is open, }\ \sup_{u,v\in U} d_Y(f(u),f(v)) \leq n^{-1} \right \} = C(f).[/tex]
The equality should be clear.
Why?
Infrared said:
Why?
Oops, that's bad expression by me. I really had in mind that [itex]u[/itex] is identified uniquely with [itex]g(z)[/itex]. But now [itex]e^u = e^v \Rightarrow e^{g(z)} = e^{g(w)}[/itex] might break. Thanks for noticing. The homemorphism part still works, but usable if [itex]g[/itex] is an inclusion as @Math_QED said.
I'll stick to my rifle at #32 for now. Yet I'm not convinced continuity is a required assumption. I get a feeling [itex]e^{g(z)} =z[/itex] forces [itex]g[/itex] to be continuous and in this case, holomorphic.
It doesn't. ##g(z)=\ln|z|+\arg(z)## is a counterexample
Of course *smacks forehead*. I had a thought maybe [itex]|z|\leq |e^z|[/itex], but that's not true in [itex]\mathbb C[/itex].
We have a function ##\beta (\theta)## for ##0 \le \theta < 2\pi## with ##\cos \beta (\theta) = \cos \theta## and ##\sin \beta (\theta) = \sin \theta##. We know that ##\beta(0) = 2\pi n## for some ##n##. As adding a constant does not effect the continuity of a function we can, wlog, take ##\beta(0) = 0##.
The technical point outstanding is that if ##\beta## is continuous, then ##\beta(\theta) = \theta##.
In general, we have ##\beta(\theta) = \theta + 2\pi n(\theta)## with ##n(0) = 0##, as above.
The only continuous functions of the form ##2\pi n(\theta)## are constant functions. I'll spare everyone an epsilon-delta proof of that. Therefore, we must have ##g(z) = i\theta = i\arg z## for ## 0 \le \theta < 2\pi##.
The second technical point is that ##\arg(z)## is discontinuous on the unit circle. I'll quote that as a known result.
In any case, that proves that ##g## cannot be continuous.
