Calc Resistance, XL-XC & Power in RLC Circuit
  • Thread starter Thread starter waywardtigerlily
    Physics
In the RLC circuit discussion, the resistance was calculated as 19.2 Ohms using Ohm's law with the given rms voltage and current. The total reactance (XL - XC) could not be determined due to a lack of specific values for inductance and capacitance. The average power dissipated in the circuit was calculated to be 867 J/sec using the formula P = VIcosθ. The phase angle of 55.9 degrees was converted to radians for accurate calculations. Overall, the discussion focused on applying formulas to solve for resistance and power while highlighting the missing information needed for reactance calculations.
waywardtigerlily
In a certain RLC circuit, the rms current is 6.72A, the rms voltage is 230V, and the current leads the voltage by 55.9 Degrees.
a)what is the resistance of the circuit?
b)calculate the total XL-Xc
c)Calc. the average power dissipated in the circuit.
a) 1.92E1 Ohms
b)?
c)8.665E2 J
I can't figure out b! I tried using
tan x = X/R
tan 55.9 = (Xl-Xc)/(1.92E1 Ohm)
But this did not give me the right answer...maybe i am just doing the math wrong here...would you do this to solve for (XL-Xc)?
(1.92E1 Ohm)tan 55.9 = "x" ?
Thanks
Your approach is right.
I get 28.36 ohms.
Note: The power is in units of energy / time. VIcos\phi = P = I^2R, so it is 867 J/sec.
AM
for your help!
a) The resistance of the circuit can be calculated using Ohm's law, which states that resistance (R) is equal to voltage (V) divided by current (I). Therefore, R = 230V / 6.72A = 1.92E1 Ohms.
b) To calculate the total XL-Xc, we need to know the individual values of XL and XC. XL is the inductive reactance, which is calculated using the formula XL = 2πfL, where f is the frequency and L is the inductance. XC is the capacitive reactance, which is calculated using the formula XC = 1/(2πfC), where C is the capacitance. Since we do not have these values, we cannot calculate the total XL-Xc.
c) The average power dissipated in the circuit can be calculated using the formula P = VIcosθ, where V is the voltage, I is the current, and θ is the phase angle between them. In this case, V = 230V, I = 6.72A, and θ = 55.9 degrees. Converting θ to radians, we get θ = 0.976 radians. Therefore, P = (230V)(6.72A)cos(0.976) = 8.665E2 J.
