Maths C Question Im having trouble with
  • Thread starter Thread starter Digital Genius
The discussion centers on evaluating the sum from r=1 to 99 of the expression 1 over √(r+1) + √r. A key step involves rationalizing the denominator by multiplying and dividing by √(r+1) - √r, which simplifies the expression. This leads to a cancellation of mid terms in the sum, making the evaluation more manageable. The final result is derived as 9 after applying the simplification. Understanding the relationship between the current problem and a previous one is crucial for solving it effectively.
Digital Genius
Evaluate:
99
∑ 1 over √r+1 + √r
r=1
this might be relevant..
the previous question was this, which i managed to solve but it still has the same fraction in it.
Show that: 1 over √r+1 + √r = √r+1 - √r , for r is greater or equal to 0
i got as far as...
T1 =
99
∑ 1 over √r+1 + √r
r=1
=0.4142
T2= 2/√2+1 + √2 ...r=2
=0.6357
OR
T2=
99
∑ 1 over √r+1 + √r......ar^n-1
r=1
a=
1 over √r+1 + √r
.....ok nevermind i have no clue haha, i did get a bit more then that but just realized it doesn't make sense... thanks for the help in advance :)
Hi Digital Genius! Welcome to PF! :)
I assume your question is:
$$\sum_{r=1}^{99} \frac{1}{\sqrt{r+1}+\sqrt{r}}$$
Hint: Multiply and divide by ##\sqrt{r+1}-\sqrt{r}##.
If your question is same as stated by Pranav, then rationalize the denominator and convert it two sum of two terms. Then you see that the mid terms cancel.
If it is as you have shown in your attempt, then why, i consider it very difficult or at least very cumbersome.
ok well according to my friends its this, but i don't see where they multiplied and divided...
=√99+1 - √r
=√99+1 -√1
=√100 - √1
=10-1
=9
any ideas??
Use your knowledge of the previous problem. If
\frac{1}{\sqrt{r+1}+\sqrt{r}} = \sqrt{r+1}- \sqrt{r}
how can you simplify
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
