Solve Matrice Problem: X = 4A - 4B
  • Thread starter Thread starter TonyC
To solve the matrix problem X = 4A - 4B, first multiply each element of matrices A and B by 4. Then, subtract the corresponding elements of the scaled matrices. This approach clarifies the steps needed to find matrix X. The discussion highlights the realization that the solution involves straightforward element-wise operations. Understanding these basic matrix operations is crucial for solving similar problems.
TonyC
I am having a problem grasping the following matrice problem: (any help is appreciated)
Solve for X given:
10 7 -6 -10 1 6
A= -10 -3 -4 B= -1 -4 0
-8 -5 -9 -5 -2 3
X=4A-4B
How do I start?
-8 -5 -9 -5 -2 3
Sorry, that didn't translate well into the post
If I understand the 'problem' correct it's just multiplying both matrices by 4 (elementswise) and then subtract them (again elementswise)... Don't youuknow how to do that?
Bingo, the light came on after I wrote it and pondered it for a while.
Thanks
