Is the given system of equations solvable with back substitution?
  • Thread starter Thread starter TyErd
    Substitution
The discussion revolves around the solvability of a system of equations with 5 variables and 3 equations. Initial thoughts suggest there may be no solution due to the imbalance in the number of variables and equations. However, one participant points out that the last row of the augmented matrix implies a specific equation, leading to further analysis. The conversation highlights that a system can have a unique solution, multiple solutions, or no solution at all. Ultimately, the conclusion is that the presence of more variables than equations does not automatically indicate no solution exists.
TyErd
I have attached the question
I think the answer is no solution because there is 5 variables but only 3 equations. Is that correct?
No, that is not the reason. Look at the final row; it is shorthand for an equation involving x1, x2, x3, x4, x5. What is the equation?
RGV
do you mean 0x1 + 0x2 + 0x3 + 0x4 + 0x5 = 4?
if the third is also an equation that means there must be an answer right? So because we have to assign variables and we have 5unknowns and 3 equations that must mean two values will be variables right?? so the answer has to be B yeah??
For what values of the variables x1, x1, x2, x3, and x4 will this be a true statement?
Not necessarily. There are three possibilities for a system of equations (which are here represented by an augmented matrix):
1) a unique solution
2) multiple solutions
3) no solution.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
