Maximizing Multi-Product Firm Profits with Symmetric Matrices
  • Thread starter Thread starter TheBestMilke
    Matrix
TheBestMilke
A multi-product firm has total cost function C(q) = qtAq and faces inter-related but linear demand schedules for the n goods it produces: q = Bp + c. Both A and B are symmetric and B is invertible. Obtain an expression for total profit π(q) in the form π(q) = qtDq - etq where D and e are appropriate matrices.
We are given that Total Cost is, C(q) = qtAq.
We also are given a production function: q = Bp + c
Total profits is just Total Revenue, p*q, minus Total Costs.
Hence:
π = p*q - C(q).
And we want to get it into a form like this:
π(q) = qtDq - etq
So far I have done some manipulation of the production function:
q = Bp+c
B-1(q-c)=p
and then substituted into the equation: π(q) = p*q-C(q) = (B-1(q-c))q - qtAq
The remaining dificulities I'm having is figuring out how to get this resulting equation to look something like the requested, π(q) = qtDq - etq. I'm also not sure if the algebra is fully legal.
While I know this isn't Physics, it's really just math. The only econ part of it is in the word problem and equation definitions. If you could help at all I would be most appreciative. If you need any more info please let me know.
Thanks!
TheBestMilke said:
π = p*q - C(q).
Try thinking about this equation right here. Remember that both \mathbf{p} and \mathbf{q} are vectors, while n is a scalar, so the "*" is scalar multiplication. But scalar multiplication can be rewritten using matrix multiplication, right? And once you write it in that form, try looking at its transpose.
I'm not sure if I completely understand, but this is what I've managed to come up with.
If we substitute the solved p value into the equation as well as the total cost we come up with something like:
n=p*q - c(q) = [B-1(q-c)]q - qAqt
If I take the transpose of the substituted p, pt, I get:
pt = [B-1(q-c)]t = (B-1)t(q-c)t = (B-1)t(qt-ct).
Am I then able to try and carry some terms through, such as:
qpt = q*(B-1)t(qt-ct) = q(B-1)tqt-B-1ctq
And then combine with the original, n = qp - c(q) into:
n = q(B-1)tqt - B-1ctq - qAqt.
In this case the B-1ct could be equal to the et but I would still have to find a way to combine the q(B-1)tqt - qAqt.
Thank you for your help. It's been quite some time since I've done anything with matrices and my brain seems to be full of rust.
I've reworked this now, trying to pay a little more attention to the way the distributive property works with matrices as well as how transpose carries through. If I start from defining the profit, n.
n = TR - TC.
TR = pq
TC = C(q) = qtAq
We know that q = Bp+c which means that B-1(q-c) = p.
Now if I take the transpose of that, I get:
pt=(B-1(q-c))t=(q-c)t(B-1)t=(qt-ct)(B-1)t=(qt-ct)(Bt)-1=(qt-ct)B-1=qtB-1-ctB-1 since we knew B was symmetrical, and therefore B=Bt
Now when I substitute that back into the equation, I get:
ptq=(qtB-1-ctB-1)q=qtB-1q-ctB-1q
If I do the same with taking C(q)t, I get:
C(q)t = (qAqt)t=qtAtq=qtAq because A is symmetrical as well.
Now, putting that all into the equation we arrive at:
n = ptq-C(q)t
n = qtB-1q-ctB-1q-qtAq=qt(B-1-A)q-ctB-1q
and that falls into the n = qtDq - etq kind of format.
*I guess the issue is this: if I let n = pq - c = ptq-ct it works. Is this possible or do I have to start from the beginning and say nt = (pq)t-ct?
I figured it out. I don't know what I was possibly thinking to begin with as it was actually a simple task. Thanks for bearing with my multiple posts and bumps.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
